Cornish Rattler Posted February 2, 2023 Share Posted February 2, 2023 Hi guys Can anyone tell me what ohm's the S3 fuel gauge uses to operate the gauge please, trying to use an after market guage Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 2, 2023 Share Posted February 2, 2023 Does this help? Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted February 3, 2023 Author Share Posted February 3, 2023 On 2/2/2023 at 9:28 AM, FridgeFreezer said: Does this help? Cheer's fridge looks like my new gauge won't do Quote Link to comment Share on other sites More sharing options...
pete3000 Posted February 4, 2023 Share Posted February 4, 2023 If you want to use aftermarket or different marque gauges, I can't speak highly enough of the gaugewizard from spiyda. Allows you to adjust/calibrate gauge and has lamp output for 2 levels for low and nearly empty. Used one for my td5 fuel gauge when the speedo output wouldn't work. Pete Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted February 4, 2023 Author Share Posted February 4, 2023 4 hours ago, pete3000 said: If you want to use aftermarket or different marque gauges, I can't speak highly enough of the gaugewizard from spiyda. Allows you to adjust/calibrate gauge and has lamp output for 2 levels for low and nearly empty. Used one for my td5 fuel gauge when the speedo output wouldn't work. Pete Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted April 1, 2023 Author Share Posted April 1, 2023 I've just found a fuel gauge that uses the same ohm's as a std one which i have just ordered so will see how it goes once it arrives Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted April 1, 2023 Share Posted April 1, 2023 (edited) There is a thread on here somewhere, a guy said if a new 127ohm resistor was put across the posts on the back of a faulty gauge it made it work again albeit a Defender type. I could never verify the claim. Regards Mark. Edited April 1, 2023 by bushwhacker Quote Link to comment Share on other sites More sharing options...
