Notimetodie Posted May 18, 2023 Share Posted May 18, 2023 (edited) Hello! I have a 2022 110 Defender and i’m having problem with my AC screen display ( the two circular buttons which shows the temperature). The buttons do not display the temperature it’s like a blank screen but they are working only display problem. I was wondering if anyone else had this issue and how would they solve it?thanks it advance Edited May 18, 2023 by Notimetodie Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 19, 2023 Share Posted May 19, 2023 Sounds like a warranty issue? You can also check the manual if there's any way to force a reboot of the system, that can fix things sometimes too. 2 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 19, 2023 Share Posted May 19, 2023 Hold the radio power button for 20 seconds with the ignition on and the car in park. That resets the pivi pro system. If no luck then it’s a dealer issue. I’ve never seen the fault before on any of the user groups. 3 Quote Link to comment Share on other sites More sharing options...
Lightning Posted September 25, 2023 Share Posted September 25, 2023 (edited) l would recommend with one of these new Defenders to buy the GAP diagnostic tool once the vehicle warranty expires. l have no connection whatsoever with this company but if you buy the tool you can access the vehicle software and read/clear faults. You can also make alterations such as remember the setting of the stop/start and turn on features not active on your vehicle, if you want to. However if it's under warranty (and the pivi pro reset mentioned above doesn't fix it) just take it back to the dealer. Edited September 25, 2023 by Lightning Quote Link to comment Share on other sites More sharing options...
