Vera2005 Posted May 22 Share Posted May 22 I have a defender 90 td5 , 2005, the headlight dip is not working. There is a buzzing noise behind the instrument panel. I removed the panel and located the buzzing relay, I replaced the relay with a brand new Lucas relay but the new relay is still buzzing. The column light switch seems ok as does the column indicator / high beam flash/ horn. I the wiring diagram shows 2 relays, 1) dim dip relay( replaced) 2) headlight relay don’t know how to locate the headlight relay?? Any suggestions or advice would be most welcome . Tonin Quote Link to comment Share on other sites More sharing options...
Paul C Posted May 23 Share Posted May 23 Your headlamp relay should be under the fuses below the centre facia, the yellow relay to the left of the brown relay. Quote Link to comment Share on other sites More sharing options...
