V8: What Clutch Slave Cylinder?
Time to get the clutch working...
I worked out last year (with help from the forum!) that the release mechanism I needed is/was like the Disco 2:
On 7/23/2022 at 6:42 PM, Phill S said:
After a lot of chasing around I found this in the discovery 2 area:
That's from here:
https://new.lrcat.com/#!/1232/38569/38570/2967/38583
For reference that can all be found here:
https://forums.lr4x4.com/topic/112315-v8-clutch-release-conundrum/#comment-1041408
Now I used the push rod, item 10 in the above diagram, FTC5199. Please don't tell me I got that wrong:
Am I right in thinking then, that I would need the slave cylinder for the 1987 spec 3.5 V8 - item 16 UKC8677L - now superseded by FTC5071?:
The only real difference from the original '87 V8 is the longer push rod to replace item 12?
Plus a revision to the slave cylinder end hydraulics to take me from 2.5NA diesel to V8 as in:
i.e. replacing the hose 16, then 17 with 18, and 21 with 22?
Also, where does bolt 23 attach?
And of course I've forgotten to identify that this is a 3.9 engine with an R380 gearbox. You were just supposed to know that....
  • Haha 1
Can't help on part numbers but I will rave about the LOF slave cylinder, fitted it to mine (V8 R380) and it's soooo much nicer, only cost a few quid more than standard too.
