forkrentfitter Posted January 14 Share Posted January 14 i am currently building a 110 king cab on a galv chassis, i am hear of p38 steering boxes being used, what is the gain and what is envolved please. Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted January 14 Share Posted January 14 You gain space in the engine bay by moving the steering box to the outside of the chassis. With this kit. P38 steering conversion kit | Blackbird Industries Cheers Dave Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted January 15 Share Posted January 15 However unless your using a twin turbo engine, an m57 with a low mount air con pump does fit without needing to swap to the p38 box Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted January 15 Author Share Posted January 15 11 hours ago, RedLineMike said: However unless your using a twin turbo engine, an m57 with a low mount air con pump does fit without needing to swap to the p38 box thanks mike, i wondered if it was a better steering box longterm? Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted January 16 Share Posted January 16 i cant say if its better or worse longterm, it certainly gives more space in the engine bay going to the P38 box, with my conversion with the electric turbo actuator, it is really close to the steering box but still has clearance Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 16 Share Posted January 16 ZF P38 steering box is way more robust and reliable. Downside is modified steering, which you will be informing your insurance company about ? Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted January 16 Author Share Posted January 16 2 hours ago, RedLineMike said: i cant say if its better or worse longterm, it certainly gives more space in the engine bay going to the P38 box, with my conversion with the electric turbo actuator, it is really close to the steering box but still has clearance is there any chance you could post pictures of your steering set up please. Quote Link to comment Share on other sites More sharing options...
SteveG Posted January 16 Share Posted January 16 You have to drill a couple of holes in the chassis and weld in crush bars, then cut out a section of the spring mount to fit, plus source the end knuckle of the p38 steering column. Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted January 16 Author Share Posted January 16 5 minutes ago, SteveG said: You have to drill a couple of holes in the chassis and weld in crush bars, then cut out a section of the spring mount to fit, plus source the end knuckle of the p38 steering column. thank you. Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 18 Share Posted January 18 What do you do about the panhard rod mounting ? I don't like the idea of cutting away the spring pan fillet. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted January 18 Share Posted January 18 1 hour ago, smallfry said: What do you do about the panhard rod mounting ? I don't like the idea of cutting away the spring pan fillet. the blackbird kit has the panhard rod mounting as part of the adapter to fit the p38 box 1 Quote Link to comment Share on other sites More sharing options...
SteveG Posted January 18 Share Posted January 18 Blackbird Industries Ltd P38 steering kit information pack.pdf Blackbird fitting instructions. Not sure I understand the concern on removing and infill of the small corner section of the spring mount, but maybe I misunderstand you. Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted January 18 Share Posted January 18 The cut is to create clearance for the uni joint onto the box. Cheers Dave Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 19 Share Posted January 19 I have to say I'd be adding some bracing elsewhere if removing that web. Mike 2 Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 19 Share Posted January 19 23 hours ago, SteveG said: Blackbird Industries Ltd P38 steering kit information pack.pdf 1.03 MB · 11 downloads Blackbird fitting instructions. Not sure I understand the concern on removing and infill of the small corner section of the spring mount, but maybe I misunderstand you. its not the infill as such, its the removal of the fillet that braces the spring pan to the top of the chassis, especially as it is the larger of the two. I would say this is structural, and a high stress area in hard use. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 19 Share Posted January 19 I think the instructions say to weld it back up, no? Quote Link to comment Share on other sites More sharing options...
SteveG Posted January 19 Share Posted January 19 2 hours ago, smallfry said: its not the infill as such, its the removal of the fillet that braces the spring pan to the top of the chassis, especially as it is the larger of the two. I would say this is structural, and a high stress area in hard use. Sorry, I get the question now - my confusion was due to nothing else being removed. Either all or some range rover classic chassis don’t have the fillets on the front, just rear… 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 19 Share Posted January 19 90 and 110 chassis has a web at the front of the spring hanger. Mike 1 Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted January 19 Author Share Posted January 19 thank you all for your input. i will be using a 4 bolt defender steering box. Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 19 Share Posted January 19 I remembered that Defenders have this fillet, I guess intended for more heavy duty use. Have a couple of Discos and RRC in the yard. Will have a look at them tomorrow, just out of interest. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted January 25 Share Posted January 25 Slight tangent but how does the P38 box affect turning with the tyres? Does it sit inside the wheel arc so to speak so doesn't affect it? Just curious because a 1UZ with factory aircon etc., is very tight to a standard 4 bolt setup. Quote Link to comment Share on other sites More sharing options...
smallfry Posted February 8 Share Posted February 8 On 1/25/2024 at 7:39 AM, Ed Poore said: Slight tangent but how does the P38 box affect turning with the tyres? Does it sit inside the wheel arc so to speak so doesn't affect it? Just curious because a 1UZ with factory aircon etc., is very tight to a standard 4 bolt setup. Been off the air for a couple of weeks ......... The 1UZ aircon compressor is on the passenger side (RHD) its the alternator that might foul the steering box, but it will clear if you get the engine high enough. Easy enough to relocate the alternator to where the aircon compressor was, but getting the belt to work is a bit more difficult. I guess you want to keep the aircon ? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted February 8 Share Posted February 8 1 minute ago, smallfry said: Been off the air for a couple of weeks ......... The 1UZ aircon compressor is on the passenger side (RHD) its the alternator that might foul the steering box, but it will clear if you get the engine high enough. Easy enough to relocate the alternator to where the aircon compressor was, but getting the belt to work is a bit more difficult. I guess you want to keep the aircon ? Either to add aircon or use it as a compressor, maybe... I've got it clearing in a mock-up, just. Quote Link to comment Share on other sites More sharing options...
smallfry Posted February 8 Share Posted February 8 In case anyone is at all interested, I have checked the chassis and vehicles we have here ......... The 90/110s and Defenders have the fillets front and rear RRCs and Disco 1s only have one at the rear Disco 2s have no fillets at all ! 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 8 Share Posted February 8 8 minutes ago, smallfry said: Disco 2s have no fillets at all ! So clearly not really a worry.... 1 Quote Link to comment Share on other sites More sharing options...
