hurbie Posted May 1 Share Posted May 1 hello all , a good friend called in distress , his 200tdi 110 broke down . so he asked if i could have a look at what's wrong with it , short journey to his home (at this point he had it towed home using his work vehicle), and on arrival the bonnet was already open , ready for a look . engine cranked over , but a bit fast , so opened the oil filler cap and as i guesed no movement on the rockers .... so we towed it to my place , and started dismantling the engine . removing the timing cover revealed this : so that's not hard to spot what's wrong .... belt is likely to be from a bleu box 😞 what i don't get is the fraying on the side of the belt , i thought that only 300tdi's have this problem ? opening the valvecover revealed this : no rockers where harmed in this event .... so a new belt , 8 new pushrods , some time and it will be good to go ... Quote Link to comment Share on other sites More sharing options...
steve b Posted May 1 Share Posted May 1 New tensioner as well? The side wear was probably during the belt failing. The number of bent pushrods suggest it went several revs during failure. Simple fix though Steve 1 Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 1 Author Share Posted May 1 10 minutes ago, steve b said: New tensioner as well? i think i will replace the tensioner , just to be sure (belt and tensioner were replaced 6 months ago ....) Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 1 Share Posted May 1 I've had the cam belt casing crack allowing the tensioner to move laterally. It was a disco 200 but worth checking. Mike Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 1 Share Posted May 1 39 minutes ago, hurbie said: no rockers where harmed in this event .... The rockers and/or shaft will probably fail soon after that. Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 1 Author Share Posted May 1 16 minutes ago, elbekko said: The rockers and/or shaft will probably fail soon after that. could be , but what is the timeframe for "soon" , the same could be said for the valve's and piston's . so where do you draw the line .... Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 1 Share Posted May 1 A dodgy tensioner can cause the edge wear on the belt. Definitely change it, and for a proper branded part this time. Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 1 Share Posted May 1 31 minutes ago, hurbie said: could be , but what is the timeframe for "soon" , the same could be said for the valve's and piston's . so where do you draw the line .... I think it was within 5K or so for me. It's been a while though, and my memory is fuzzy. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 2 Share Posted May 2 9 hours ago, hurbie said: could be , but what is the timeframe for "soon" , the same could be said for the valve's and piston's . so where do you draw the line .... I've only ever had two rockers fail, out of a fair number of belt failures Caused by a dodgy crank seal and pulley. Never had a rocker shaft fail but have had a cam snap (no belt failures I know of). So I'd just run it. Mike Quote Link to comment Share on other sites More sharing options...
