landroversforever Posted May 16 Share Posted May 16 On 5/15/2024 at 7:02 PM, Ed Poore said: I'm not sure. My sister got a single gang Ethernet wall plate from TLC which you don't even have to crimp the wires into a connector. Just push them into something akin to a scotchblock behind the panel, there is a tool but I just used a screwdriver. https://www.tlc-direct.co.uk/Products/GU7071.html I've seen mains and Ethernet but they use power line in the back rather than dedicated cat 5. Edit I didn't know what to expect but the Cat 5 cable is completely separate from the mains within the armour so it's basically a "normal" but shielded Cat 5 bundled with the normal mains wiring. I've only ever seen that type of ethernet socket. Quote Link to comment Share on other sites More sharing options...
