2.5 td power steering pump
1990 2.5TD... Ummm... that'll be a NTC8287 pump then? (same as an early 200Tdi)
I do have a pump knocking around somewhere but I'm not sure if it's a NTC8287 or a ETC9077, I'll have to have a dig around and see if I can locate it.
I think (but am not sure) that the ETC9077 is slightly longer than the NTC8287 so would be no good to you as your pulleys will no longer line up. :huh:
 Share
