MECCANO Posted February 10, 2007 Share Posted February 10, 2007 if you were to use a 200tdi with out an oil cooler, would you essentially put a short length of pipe across where the cooler would go? or is there an easier way? Quote Link to comment Share on other sites More sharing options...
Andy Posted February 10, 2007 Share Posted February 10, 2007 i guess thats the easy way, not sure id want to run a tdi without an oil cooler though. LR must have fitted it for a reason? Quote Link to comment Share on other sites More sharing options...
MECCANO Posted February 10, 2007 Author Share Posted February 10, 2007 i guess thats the easy way, not sure id want to run a tdi without an oil cooler though. LR must have fitted it for a reason? well i lie, its actually if i use a 200tdi oil filter assembley on a 2.25 petrol engine. its a long story Quote Link to comment Share on other sites More sharing options...
Andy Posted February 10, 2007 Share Posted February 10, 2007 ahh ok. just had another thought. two bolts of the correct threads to close the holes where the pipes go in/out of? im assuming coolers arent full flow for this to work. Quote Link to comment Share on other sites More sharing options...
MECCANO Posted February 10, 2007 Author Share Posted February 10, 2007 ahh ok. just had another thought. two bolts of the correct threads to close the holes where the pipes go in/out of? im assuming coolers arent full flow for this to work. well from what i can see there is a thermostatic control on it Quote Link to comment Share on other sites More sharing options...
andyb Posted February 10, 2007 Share Posted February 10, 2007 well i lie, its actually if i use a 200tdi oil filter assembley on a 2.25 petrol engine. its a long story If that is so that you can fit a 'spin on' oil filter then the 2.5 filter assemble fits the 2.25 and gives you a spin on filter. HTH Quote Link to comment Share on other sites More sharing options...
MECCANO Posted February 10, 2007 Author Share Posted February 10, 2007 If that is so that you can fit a 'spin on' oil filter then the 2.5 filter assemble fits the 2.25 and gives you a spin on filter.HTH its so i get more clearance on for engine mounts, that will allow me to fit a lt77, followed soon after by a 200tdi into my light weight once the 200tdi is fitted i will put the assembley back to using the oil cooler Quote Link to comment Share on other sites More sharing options...
andyb Posted February 11, 2007 Share Posted February 11, 2007 its so i get more clearance on for engine mounts, that will allow me to fit a lt77, followed soon after by a 200tdi into my light weightonce the 200tdi is fitted i will put the assembley back to using the oil cooler Oh right. Best of luck Quote Link to comment Share on other sites More sharing options...
MECCANO Posted February 11, 2007 Author Share Posted February 11, 2007 Oh right. Best of luck Going to need it Quote Link to comment Share on other sites More sharing options...
