gelf Posted February 10, 2007 Share Posted February 10, 2007 My 200 tdi has develpoed a starting problem........ ive traced it to the brown wire from the starter soleniod which then (according to the wiring diagram) goes to a fusable link.....cant find it though or trace the wire to it. so where are they?? on a 300tdi there under the bonnet. have rigged up a temp wire so i can now start it... but i want to sort it properly. thanks graham Quote Link to comment Share on other sites More sharing options...
imspanners Posted February 10, 2007 Share Posted February 10, 2007 Folow the battery+ wire from the battery along the inner wing. Under the tape you'll see some net style material covering the wires. These are the fusible links. Cut the netting off at either end and grab each wire where it's soldered to the main loom. Give a good tug, and you'll find they seperate due to corrosion. A replacement battery loom with fusible links in is available from LR. Quote Link to comment Share on other sites More sharing options...
imspanners Posted February 10, 2007 Share Posted February 10, 2007 Folow the battery+ wire from the battery along the inner wing. Under the tape you'll see some net style material covering the wires. These are the fusible links. Cut the netting off at either end and grab each wire where it's soldered to the main loom. Give a good tug, and you'll find they seperate due to corrosion. A replacement battery loom with fusible links in is available from LR. I think the LR part number is AMR3927 but that needs checking. Quote Link to comment Share on other sites More sharing options...
gelf Posted February 10, 2007 Author Share Posted February 10, 2007 thank you. Quote Link to comment Share on other sites More sharing options...
