Wolf clutch slave cylinder push rod problem
Droptank
Having renewed the clutch slave cylinder I was replacing the pushrod and a new clip when unfortunately it fell into the bell housing, is this likely to cause a problem with say the starting ring gear or obstruct anything in the bell housing or is it a gearbox out job to remove it?
Any advice will be much appreciated.
