mad_pete Posted September 23 Share Posted September 23 I have a a ported 3.5 rover v8 inlet manifold. How interchangeable is that with a 4.2 one? I’d want to keep the cover and the fuel rail from the 4.2 but use the manifold from the 3.5. Are they the same enough to do that ? This is the 3.5 one on the bench. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 23 Share Posted September 23 I believe they are compatible, the base inlet almost the same going up to 99 on the P38, just maybe some slight differences in coolant pipe and temp sender/sensor placements. 1 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted 2 hours ago Share Posted 2 hours ago As Bowie says, the machining is subtly different (some holes not tapped later on etc. as stuff was omitted) but the basic castings are identical. 3.5 Flapper left, 3.9 Hotwire (same as 4.2) right: Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted 50 minutes ago Share Posted 50 minutes ago Yes 3.5 will fit gas 8th injector (blank off) and doesn’t have stepper gubbins on rear face but can be retro added linkage between 3.5 and other is bigger and different but can be swapped about Quote Link to comment Share on other sites More sharing options...
