Green200tdi Posted yesterday at 12:45 PM Share Posted yesterday at 12:45 PM (edited) Hello all, sons d2 am I right in thinking the interior lights are constant live? battery … fuse box …. Light, x3 and the on/off is done by doors/BCU ect? as have No power to them at all checked the 3 fuses I read about online F15…….20amp F16…….15amp F20…….15 amp iirc 😂 Edited yesterday at 12:47 PM by Green200tdi Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted yesterday at 02:11 PM Author Share Posted yesterday at 02:11 PM 1 hour ago, Green200tdi said: Hello all, sons d2 am I right in thinking the interior lights are constant live? battery … fuse box …. Light, x3 and the on/off is done by doors/BCU ect? as have No power to them at all checked the 3 fuses I read about online F15…….20amp F16…….15amp F20…….15 amp iirc 😂 Also what does this box do? Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted yesterday at 03:08 PM Share Posted yesterday at 03:08 PM Yes Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted yesterday at 06:51 PM Author Share Posted yesterday at 06:51 PM 3 hours ago, Nonimouse said: 3 hours ago, Nonimouse said: Yes Well that’s short n sweet,😂 ok so no live we have a brake in the system somewhere. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted 13 hours ago Share Posted 13 hours ago Normally interior lights are permanent live and switched earth. All the door switches just connect to the body hence they only have one wire. Assuming the black box is on the interior lights circuit purple and white cable from memory, it's probably a timer, triggered by the door switch it'll keep a connection to earth once the doors shut for x number of seconds then disconnect thus turning the lights off. Mike Quote Link to comment Share on other sites More sharing options...
Arjan Posted 13 hours ago Share Posted 13 hours ago D2 interior lights are constant live and work through the BCU (you can play with them) Quote Link to comment Share on other sites More sharing options...
Maverik Posted 12 hours ago Share Posted 12 hours ago 17 hours ago, Green200tdi said: Also what does this box do? The black box is the receiver for your alarm key-fob. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted 12 hours ago Share Posted 12 hours ago They work in the same way as a Defender's which uses the 10AS unit. That monitors the door switches and controls the 0V side of the lights. In that way they can be controlled when the doors are closed (like when the alarm is set/unset and the lights go off/on). Quote Link to comment Share on other sites More sharing options...
Maverik Posted 12 hours ago Share Posted 12 hours ago Just now, Peaklander said: They work in the same way as a Defender's which uses the 10AS unit. That monitors the door switches and controls the 0V side of the lights. In that way they can be controled when the doors are closed (like when the alarm is set/unset and the lights go off/on. Apart from a D2 doesn't use a 10AS the alarm and interior lights are integrated into the Body Control Unit (BCU) - [black box under in passenger foot-well] and the Intelligent Driver Module (IDM) - [integrated fuse-box under steering wheel] - they work together. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted 12 hours ago Share Posted 12 hours ago Yes, I just meant that it's the same principle and the OP asked the same question ref. a Defender some months ago. Quote Link to comment Share on other sites More sharing options...
Maverik Posted 12 hours ago Share Posted 12 hours ago Have a read of this in the relevant sections - very useful IMHO. Discovery Series II Technical Academy Brochure - Eng (fuddymuckers.co.uk) Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted 8 hours ago Author Share Posted 8 hours ago So this morning we managed to get the lights working ( never worked sinse some brough car)🙄 see pics by adding a constant live to the left terminal of front front light which livened up all 3 interior lights but still don’t seem to work on doors or fob but will read posts so we have a broken live wire I guess somewhere along the line? Quote Link to comment Share on other sites More sharing options...
teabag Posted 2 hours ago Share Posted 2 hours ago All you’re doing with that piece of wire is what the interior light fittings switch providing an earth connection that the BCU which looks after and also the light illumination delays and the interface with the central locking. You will find a “box” above the headliner that is the fob receiver, as already been mentioned. You may also find another “box which is a radio signal amplifier connected to the o/s side window antenna. 1 Quote Link to comment Share on other sites More sharing options...
