water in drivers footwell
williams31
:o Can someone please help me the windscreen on my freelander is misted up when i come to drive it on further inspection i have found water under the carpet in the drivers footwell . The passenger side is dry and the back, I cannot see any leaks around the door seal or the windscreen nor is the rear washer pipe leaking as this runs along the drivers side floor any help would be gratefully received
check it is not the air con drains blocked, not sure where they are on a Freelander but it would almost certainly cause windscreen misting and soggy footwells.
aircon cools the air and removes moisture and the moisture would normally drain out underneath, if the drain tube gets blocked or kinked then the water has to go somewhere!
