Posted
Hello collective,
My Defender came with tubular shock mounts on, I'm not sure if they are made specifically for the +2 lift it has, I'm about to remove the lift kit and go back to standard.
Could someone please tell me how tall the front shock towers are so I can check to see if mine need replaced with normal height ones.
Posted
Personally I would replace them anyway and would use the Galvanised ones NRC6372GALV you get change out of 22 (×1) quid from island 4x4. Would also get the stainless steel retaining ring then it's pretty much fit and forget in that department.
  • Like 2
