bishbosh Posted September 24, 2005 Share Posted September 24, 2005 OK, so there I was in the garage looking for my panel fettling stick and I came across an old mud flap lying about in a corner. The panel work was required as I managed to smash both my indicator / sidelight clusters at Bampton and in the process separated the wing skin from the front bit wotsit. (aren't pop rivets marvelous! ) Anyhow, I digress - this is not the first time I have smashed the light clusters on the rangie and I now have to wait for Old Sodbury to (hopefully) pick up some spares on the cheap. I had been mulling over putting an ali skin over the hole left by the rangie lights and sticking on some Landy ones as they're cheaper to replace but decided against it would still leave me with lights that were vulnerable. The mud flap gave me the idea to fit a piece of stiff rubber around the corner and fit some low profile light units like these into the rubber perhaps with an ali backing strip: That way, if ( more like when the way I drive! ) I clout them the rubber would give and prevent the lights smashing. I know it's not exactly going to look like it came out of the show room, but it could remove a fair bit of buggeration in the future. Does anyone know if I'd have problems at the MOT? They're not directional lights like the headlights but I don't know if there are any peculiar rules requiring them to be fitted to "rigid" bodywork? When you've all stopped laughing you can tell me what you think! Quote Link to comment Share on other sites More sharing options...
fisha Posted September 24, 2005 Share Posted September 24, 2005 i reckon you'd get away with it. assuming they are e-marked, then it would probably come down to the discretion of the MOT man over the issue of them being "securely" fitted. Best suggestion . . . go to the MOT man and ask him if her would fail you? my local chap will tell me either way happily. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted September 24, 2005 Share Posted September 24, 2005 When you've all stopped laughing you can tell me what you think! I think if you got stuck more you spend less time driving into trees Quote Link to comment Share on other sites More sharing options...
02GF74 Posted September 26, 2005 Share Posted September 26, 2005 get it from the horse's mouth by filling out the MOT query form here Quote Link to comment Share on other sites More sharing options...
rtbarton Posted September 26, 2005 Share Posted September 26, 2005 I was thinking along the same lines when I had a Rangie. I thought that £30 (at the time) for a plastic lens was excessive. I toyed with the idea of making a plate and using the ordinary Landy side & indicator lights. I think it would look quite nice too with all round lights at the front. Quote Link to comment Share on other sites More sharing options...
M005 Posted September 26, 2005 Share Posted September 26, 2005 Have you thought of putting them inside the headlights; i.e. in the grill? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 27, 2005 Share Posted September 27, 2005 I've seen people mount standard series lights on top of wings / bonnet, they'd be fairly safe there unless you rolled it Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 27, 2005 Author Share Posted September 27, 2005 Have you thought of putting them inside the headlights; i.e. in the grill? Interesting idea....... althoug I don't like the idea of indicators inboard of the lights - just doesn't seem right but it would make them relatively safe.......... I wondier if there's room.... I've seen people mount standard series lights on top of wings / bonnet, they'd be fairly safe there unless you rolled it Now that's just daft..... or is it, maybe some forward facing surface mount units like they put on artic truck roofs.... Quote Link to comment Share on other sites More sharing options...
darthdicky Posted September 27, 2005 Share Posted September 27, 2005 Mercedes G-Wagons had them mounted on the top of the wings at the front - might be able to find some of those to put on the bonnet? Quote Link to comment Share on other sites More sharing options...
gruntie Posted September 28, 2005 Share Posted September 28, 2005 VW Beetle front indicators? Indicators Stick the sidelights in the headlights? Quote Link to comment Share on other sites More sharing options...
yellow Posted September 28, 2005 Share Posted September 28, 2005 I was thinking along the same lines when I had a Rangie. I thought that £30 (at the time) for a plastic lens was excessive.I toyed with the idea of making a plate and using the ordinary Landy side & indicator lights. I think it would look quite nice too with all round lights at the front. Should the side lights and the indicators not be on the outside of the vehicle, ie on the corner. I believe MOT will fail you when the indicators are between the headlights if these are independent units. Quote Link to comment Share on other sites More sharing options...
MogLite Posted September 28, 2005 Share Posted September 28, 2005 Those low profile lights you show, are NAS lights, as fitted to amongst other things - my Ibex. They are expensive for what they are, and come with crappy modern connectors. If I were you I'm mount a couple of series lights in a rubber/ali panel. But keep the regular lights for MOT/road trips. Mainly cause I think it will look pretty low-rent on a nice Rangie like yours. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 28, 2005 Author Share Posted September 28, 2005 Mainly cause I think it will look pretty low-rent on a nice Rangie like yours. Was that before I after you had me dragged backwards through that bank at Slindon.... I think that'll be the way I'll be heading unless I can get some seriously cheap spares at Sodbury.... we shall see. Quote Link to comment Share on other sites More sharing options...
