brds Posted February 17, 2007 Share Posted February 17, 2007 Hi to everyone from Norway My first post after enjoying reading this great forum for some time. Have a 110 V8 which I have put a RR EFI engine in, now I want to change the gearbox to a ZF auto and a DIsco lt230 to get slightly higher gearing. Will a ZF from a RR with Borg Warner transferbox fit a LT 230? The reason I am asking is that the lever from the transferbox interferes with the ZF Housing Is this the only problem I will have or just the first of a series? Thanks Quote Link to comment Share on other sites More sharing options...
ashtrans Posted February 17, 2007 Share Posted February 17, 2007 Hi to everyone from NorwayMy first post after enjoying reading this great forum for some time. Have a 110 V8 which I have put a RR EFI engine in, now I want to change the gearbox to a ZF auto and a DIsco lt230 to get slightly higher gearing. Will a ZF from a RR with Borg Warner transferbox fit a LT 230? The reason I am asking is that the lever from the transferbox interferes with the ZF Housing Is this the only problem I will have or just the first of a series? Thanks you can remove the BW and fit the 230 no problem, you will need to use the disco hi/lo and diff lock linkages and mount the lever to a FRC8558, swan neck mounting bracket, Dave Quote Link to comment Share on other sites More sharing options...
brds Posted February 18, 2007 Author Share Posted February 18, 2007 you can remove the BW and fit the 230 no problem,you will need to use the disco hi/lo and diff lock linkages and mount the lever to a FRC8558, swan neck mounting bracket, Dave Thanks Dave Quote Link to comment Share on other sites More sharing options...
