Yostumpy Posted February 17, 2007 Share Posted February 17, 2007 must share this with you, had the usual 1 second delay follwed by clacks when pulling away or changing thro' the gears, changed 3 of the drive members and woh what a difference, like a new truck! no delay, no clacking. Why change 3 not 4? well front n/s rusted solid, big hammer and chisel bounced off. oh well at least its not slack. cheep fix to around £50 for 4 from paddocks, certainly worth an hours graft. Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted March 11, 2007 Author Share Posted March 11, 2007 UPDATE!! finally got round to doing no.4 front n/s as the bearing was now rumbling a bit. took out the bolts, wheel off, BIG bolster and even bigger hammer. NO!! I managed to slightlyseperate them about 1mm, but all this did was tighten ou the bearing so i couldnt rotate the hub at all. It just wouldnt budge. I know I'll drilla line of holes and the get the bolster and try to................ NO! the drills wouln't touch it!! BUGGA! starting to get a bit dark now and I still coulnt rotate the hub. This thing was well rusted on there. Look in garage and find my old dads hack saw with 1 blade. HMMMM!!! well I cut all the way round the drive member in the lip that holds on the rubber cap, as far down as i dare with out cutting the splines, then split it off with the hammer a bolster, 1/2 way there!! then i could concerntrate on seperating the rest of the member from the hub. Hit my hand twice with lump hammer OUCH! whole job (1) took 2 1/2 hours, so make sure your slines are well greased!! Quote Link to comment Share on other sites More sharing options...
