selectcase Posted February 17, 2007 Share Posted February 17, 2007 I will post some pics tomorrow when its light but basically I have a discovery 200tdi turbo & manifold as well as the normal 2 oil feed holes on the turbine body there are to water pipe inlet and outlet holes, the water pipes connected to a modified heater pipe over the inlet manifold and a junction on the thermostst I didnt realise it was any differant until i bought another 200tdi engine and compared the turbos - they look identical in every other way exept the turbine body/housing does not have the cooling fins. the casting numbers on the aluminium inlet side are also identical any ideas? Pictures below Quote Link to comment Share on other sites More sharing options...
white90 Posted February 17, 2007 Share Posted February 17, 2007 Maurice Murphy had a water cooled turbo on his 300TDI previously he may know Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted February 17, 2007 Share Posted February 17, 2007 I will post some pics tomorrow when its light but basically I have a discovery 200tdi turbo & manifold as well as the normal 2 oil feed holes on the turbine body there are to water pipe inlet and outlet holes, the water pipes connected to a modified heater pipe over the inlet manifold and a junction on the thermoststI didnt realise it was any differant until i bought another 200tdi engine and compared the turbos - they look identical in every other way exept the turbine body/housing does not have the cooling fins. the casting numbers on the aluminium inlet side are also identical any ideas? I know this is an option on hybrid turbo's sold by allards. Andy Quote Link to comment Share on other sites More sharing options...
selectcase Posted February 18, 2007 Author Share Posted February 18, 2007 A hybrid turbo! That could make sense as it had samco sport hoses and new braded oil feed pipes etc i will deffo check in the morning as i really want a good standard turbo a tuned hybrid jobbo might be a bit too much for my s2a 88 Quote Link to comment Share on other sites More sharing options...
BrUcE Posted February 18, 2007 Share Posted February 18, 2007 I will post some pics tomorrow when its light but basically I have a discovery 200tdi turbo & manifold as well as the normal 2 oil feed holes on the turbine body there are to water pipe inlet and outlet holes, the water pipes connected to a modified heater pipe over the inlet manifold and a junction on the thermoststI didnt realise it was any differant until i bought another 200tdi engine and compared the turbos - they look identical in every other way exept the turbine body/housing does not have the cooling fins. the casting numbers on the aluminium inlet side are also identical any ideas? Do you feel any difference? Sounds like I wish I found that on mine. Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted February 18, 2007 Share Posted February 18, 2007 A hybrid turbo! That could make sense as it had samco sport hoses and new braded oil feed pipes etc i will deffo check in the morning as i really want a good standard turbo a tuned hybrid jobbo might be a bit too much for my s2a 88 I could find a home for it if it is unwanted I have a good spare turbo for part exchange aswell Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 18, 2007 Share Posted February 18, 2007 I had one but I have no idea what it was off I'm afraid. I replaced mine with a standard 300 turbo as I had no need for the added complication of such items. Mo Quote Link to comment Share on other sites More sharing options...
selectcase Posted February 18, 2007 Author Share Posted February 18, 2007 I could find a home for it if it is unwanted I have a good spare turbo for part exchange aswell Sounds fine to me, I will get some pictures up later today so you can have a look cheers wil Quote Link to comment Share on other sites More sharing options...
selectcase Posted February 18, 2007 Author Share Posted February 18, 2007 Pictures add now to first post Quote Link to comment Share on other sites More sharing options...
Andy Posted February 18, 2007 Share Posted February 18, 2007 bet you'd have a good heater running that. lot of work for warmth though? Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 18, 2007 Share Posted February 18, 2007 I have 1 of those turbos, but I need 2 new banjo fittings for the coolant side of life so I can get it fitted. Does anyone know of where to get them from. Looked in a few nut and bolt shops but no joy. Ralph- Is there any banjo bolts within the LR parts system that would be up to the job? JST/Tony C Is there anywhere local to you that sells that sort of stuff? Quote Link to comment Share on other sites More sharing options...
western Posted February 18, 2007 Share Posted February 18, 2007 Ralph- Is there any banjo bolts within the LR parts system that would be up to the job? /quote] banjo bolts on Defender 200Tdi ERR1125 injection pump fuel inlet ERR886 injection pump STC3297 injectior pipes/injectors ERR1200 6mm spill pipe on injectors hth Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 18, 2007 Share Posted February 18, 2007 Ralph You're a star Quote Link to comment Share on other sites More sharing options...
western Posted February 18, 2007 Share Posted February 18, 2007 RalphYou're a star don't know if any of those will fit as EPC doesn't tell me the thread details. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 18, 2007 Share Posted February 18, 2007 Ralph Knowing the size of the threads on my turbo I'd confidently say that they are all to small. Will give Allards a call to see what they have to say. Many thanks for looking up the numbers though. Quote Link to comment Share on other sites More sharing options...
western Posted February 18, 2007 Share Posted February 18, 2007 OK, I've not seen a turbo with those connections before. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 18, 2007 Share Posted February 18, 2007 Just waiting to see if Tony or James can throw some light on local suppliers now. Quote Link to comment Share on other sites More sharing options...
selectcase Posted February 18, 2007 Author Share Posted February 18, 2007 I can get one out and measure it f you like wont be til tomorrow now - a 19mm spanner fits the head and they are quite big cheers will Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 18, 2007 Share Posted February 18, 2007 Will That would be grand. Any ideas of somewhere local to you up in Bridgy where I could get a couple? Quote Link to comment Share on other sites More sharing options...
selectcase Posted February 18, 2007 Author Share Posted February 18, 2007 Hickleys are a good bet thats where James goes i think Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 18, 2007 Share Posted February 18, 2007 Cheers will call in there tomorrow on the way through to Minehead. Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted February 19, 2007 Share Posted February 19, 2007 Spoke to Alan Allard today about the turbo, can't tell from the outside if it is a hybrid or not, the serial number might indicate but not certain, however if it has a water cooled centre and braided oil pipe etc it seems unlikely that someone would have gone to this much trouble for a standard turbo. Apparently they machine the back of the compressor housing a little to make it a little bigger and use a larger compressor wheel, at least that's as I understood it , I assume they use a better bearing also. Andy Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted February 19, 2007 Share Posted February 19, 2007 Ive seen these before...but fitted to a Saab 93. You have something special there.... Quote Link to comment Share on other sites More sharing options...
