Mean Green Posted September 25, 2005 Share Posted September 25, 2005 My Defender has been sitting on my drive for the last few weeks since the clutch went. During this time the fatory fitted oil leaks have stained the mono-bloc. So can anyone suggest any good products or tips on removing engine oil/diff oil and gearbox oil from monoblocs. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted September 25, 2005 Share Posted September 25, 2005 Not sure what monobloc is but DONT burn it off. The concrete under an oil patch exploded when we tried to burn some oil off a mates drive. There is now a divot about 3/4" deep in his drive Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 26, 2005 Share Posted September 26, 2005 You can get various types of concrete cleaners, but unfortunately oil soaks into the block and leaves a permanent stain. It'll fade with time, but perhaps replecing the damaged blocks is the only best option. Les. Quote Link to comment Share on other sites More sharing options...
Mean Green Posted September 26, 2005 Author Share Posted September 26, 2005 Cheers Les, I had a feeling that might be the case. I tried to protect the blocks by putting a drip tray underneath, but it must have blown away! Will have a go with good ol' fairy liquid and the power washer and see what happens. Also heard rumours that Coca-cola and washing powder are good for cleaning concrete, do they also work on monobloc? Quote Link to comment Share on other sites More sharing options...
jules Posted September 26, 2005 Share Posted September 26, 2005 Don't laugh Use Petrol this will dilute the engin oil to a much weaker stain if you do it early enough it will take the stain totaly, a few liters should do it. Otherwise use brick acid or oil remover from the likes of Jewson or Travis Perkins I have found on the garage floor thats floted concrete, the petrol takes any oil off and the petrol wet mark stain lasted a day or so untill its all evaperated off. I'm a construction site manager so I am used to cleaning oil off concrete and block paving from the JCB's and dumpers on site. Don't smoke while cleaning Julian Quote Link to comment Share on other sites More sharing options...
Mark90 Posted September 26, 2005 Share Posted September 26, 2005 I've used Gunk degreaser to good effect on concrete in the past. Quote Link to comment Share on other sites More sharing options...
donaldh Posted September 26, 2005 Share Posted September 26, 2005 I've successfully used Gunk driveway cleaner to get oil off monobloc. You need to give it time to really dilute the oil before washing off and you need to use lots of soapy water to wash the gunk away. Alternatively, you could try turning the blocks upside down. Quote Link to comment Share on other sites More sharing options...
02GF74 Posted September 26, 2005 Share Posted September 26, 2005 The only solution that will successfully hide the stained blocks is to pour the same coloured oil over all the monblocks (whatever they may be!) and working it into the crevices and cracks with a stiff bristle brush. Quote Link to comment Share on other sites More sharing options...
jules Posted September 26, 2005 Share Posted September 26, 2005 You jest I've seen that done. a JCB blow a back acter hose and sprayed oil every were so the groung worker to clean up filled a garden sprayer with hydrolic oil and covered every thing with it on the monday when the site reopend it just looked like it had the sealing coat applied. so the cliant though he got his paving fully sealed for free. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted September 26, 2005 Share Posted September 26, 2005 My drive is being done this week, but I've specified black blocks so the oil won't show up quite as much Quote Link to comment Share on other sites More sharing options...
