relay problem
tracengrant
hi there can any one help me please my indicators work all round but they dont flash on the display as it is an mot failure i need to get it sorted. I am just in the process of getting a used indicator/wiper stalk could this be the problem or is it the relay. Is there 1 or 2 relays for the indicators.
Will the stalks be easy to fit to my discovery 200 tdi
thank you
Both my discos have had this fault. Swap the big relay for a know good one and I think your problem will go away. The winker relay is IIRC near the steering column above the pedals rather than behind the side footwell panel. It is the one thats obviously bigger than all the others. Quite expensive so worth borrowing one to be sure its the problem (or to get through the MOT ;) )
