western Posted September 28, 2005 Share Posted September 28, 2005 Now I 've got hold of a newer clutch pedal with the spring.....But the spring ai'nt attached just exactly how does it fit ? please thanks This should help Quote Link to comment Share on other sites More sharing options...
will_warne Posted September 29, 2005 Share Posted September 29, 2005 Les, fit an auto into the hybrid. I'm sure it'll go into an 88 inch without too many dramas; I've had no major problems getting my box into the 90. You may need to move the engine arround a bit to keep the propshafts a sensible length. Quote Link to comment Share on other sites More sharing options...
SimonPearson Posted September 29, 2005 Share Posted September 29, 2005 ... and on that note, Les if you need one several months ago I tracked down a recon ZF Auto from a 300Tdi that is complete with everything. As I've now got an Isuzu 2.8TD I won't be using it, so it's available. I even sourced a 200Tdi ZF Auto backplate from Ashcrofts for it. Lemme know. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted September 29, 2005 Author Share Posted September 29, 2005 ... and on that note, Les if you need one several months ago I tracked down a recon ZF Auto from a 300Tdi that is complete with everything. As I've now got an Isuzu 2.8TD I won't be using it, so it's available. I even sourced a 200Tdi ZF Auto backplate from Ashcrofts for it. Lemme know. Simon, please PM me with the details and how much ! just how short a rear prop can i get away with ? Quote Link to comment Share on other sites More sharing options...
SimonPearson Posted September 29, 2005 Share Posted September 29, 2005 PM sent les - just don't let the Boss see! :-) Quote Link to comment Share on other sites More sharing options...
