Warthog Posted February 23, 2007 Share Posted February 23, 2007 Been looking at them for awhile now. Anyone running them and are there any downfalls to them? The one's in question are those from Straight Forward Supps. Cheers Mark Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted February 24, 2007 Share Posted February 24, 2007 I have them fitted had a coded welder do them for me and no leaks. Passed MOT with them fitted too. Quote Link to comment Share on other sites More sharing options...
simonr Posted February 24, 2007 Share Posted February 24, 2007 The trouble is, it's very difficult to compete on cost with the Straightforward ones. Once you have had them laser cut and bought all the fixings, you save about £10 compared to just buying the things! Obviously there is an economy of scale for them, but I don't believe their margins can be very big! Si Quote Link to comment Share on other sites More sharing options...
ebo Posted February 24, 2007 Share Posted February 24, 2007 I built my beadlocks about 4 years ago,i saw a review of rockstompers diy kit in a yank 4x4 mag and made my own version of theirs. The only problem with rockstomper and straightforwards design is that it is welded straight to the wheel without prepping it first. With my wheels i ground the outer lip down to about 60degrees,the same was done with the inner beadlock ring.This gives it a nice v prep. the grinding and welding were done on a jig i made(1 1/2 solid bar welded to a scrap stub axle,then an old landy hub bolted to stub axle),once clamped in vice the wheel would spin perfectly true. Then its just a matter of tacking inner ring on,making sure its true,then weld it on solid.I had the rings laser cut locally for £20 a ring,nuts,bolts and washers came from work. Also no difference to running normal wheels on the road even at motorway speeds hope this helps ian Quote Link to comment Share on other sites More sharing options...
pritch1 Posted February 24, 2007 Share Posted February 24, 2007 have a look at these i di them for 120 quid. they work really well im very happy http://forums.lr4x4.com/index.php?showtopi...l=what+pressure? Quote Link to comment Share on other sites More sharing options...
Chris Abel Posted February 24, 2007 Share Posted February 24, 2007 I had some made for 15 inch rims but im now going to be using 16 inch rims so ive got a set of five for sale on ebay. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...p;rd=1&rd=1 Quote Link to comment Share on other sites More sharing options...
portal pete Posted February 24, 2007 Share Posted February 24, 2007 Ive been running beadlocks for about 4 years now and found them to be a major advantage. The only trouble i found was the weight gain but then it is in the right place. currantly building a set of double beadlocks with the plastic insert . Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted February 24, 2007 Share Posted February 24, 2007 Ive been running beadlocks for about 4 years now and found them to be a major advantage. The only trouble i found was the weight gain but then it is in the right place. currantly building a set of double beadlocks with the plastic insert . I've just priced up getting some Stazworks sent over, to dear for me. I've been looking at having a go(Paying someone) to do doubles, got a plan but don't know where to go for the plastic inserts can you help? Andy Quote Link to comment Share on other sites More sharing options...
portal pete Posted February 24, 2007 Share Posted February 24, 2007 I've just priced up getting some Stazworks sent over, to dear for me. I've been looking at having a go(Paying someone) to do doubles, got a plan but don't know where to go for the plastic inserts can you help?Andy A company in birmingham make them to any size you require, i was quoted £25 per ring for 17inch rims, you can get them on 01213444484 Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted February 25, 2007 Share Posted February 25, 2007 A company in birmingham make them to any size you require, i was quoted £25 per ring for 17inch rims, you can get them on 01213444484 Excellent, fairly local aswell. Thank you Andy Quote Link to comment Share on other sites More sharing options...
will_warne Posted February 25, 2007 Share Posted February 25, 2007 I'd be interested in some inserts as well - that's the hard part to get hold of. Pete, do you plan to use the inserts as single peice or cut them so they can be taken appart, placed inside the tyre and then slotted back together to make fitting easier. Quote Link to comment Share on other sites More sharing options...
portal pete Posted February 26, 2007 Share Posted February 26, 2007 I'd be interested in some inserts as well - that's the hard part to get hold of.Pete, do you plan to use the inserts as single peice or cut them so they can be taken appart, placed inside the tyre and then slotted back together to make fitting easier. Hi will, the company will make them to any size/spec you require, i will be running single piece so will have to squash them lik a bean to get inside the tyre. I plan to run tubes aswel so the less sharp edges inside the better. Quote Link to comment Share on other sites More sharing options...
