Orange Posted February 24, 2007 Share Posted February 24, 2007 I purchased a new set of Lockheed (Delphi) brake pads from Bearmach a few days ago in readiness for replacing the rear hub oil seal (oil on the pads) and when I took the pads out of the box I found that the wear sensor was in a different position to the pads that came out. Old pad on the left (not overly worn, but worth replacing as I was doing the other side anyway) and new pad on the right. Does anyone know if this is wrong, or whether different makes of pads have different arrangements for the sensor?? I've fitted the pad for the time being. Had to trim the plug slightly, but nothing major. I would just like to know i'm going to be taking it apart again to get the right pads?? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 24, 2007 Share Posted February 24, 2007 Can't see it make any practical difference as long as you can route the wire OK. The inner pad always seems to wear fastest so fit the pad with the sensor there. Chris Quote Link to comment Share on other sites More sharing options...
smo Posted February 24, 2007 Share Posted February 24, 2007 As long as it fits properly then i cant see why it should be problematic. Quote Link to comment Share on other sites More sharing options...
Andy Posted February 24, 2007 Share Posted February 24, 2007 just make sure the wire doesnt rub on the hub with the new ones. i just cut the wires off my pads as the bit they connect to got ripped off offroading years ago. Quote Link to comment Share on other sites More sharing options...
Orange Posted February 24, 2007 Author Share Posted February 24, 2007 Cheers guys! Was just making sure as I've put it together and routed the cable so it doesn't rub the hub, so all should be fine! Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted February 25, 2007 Share Posted February 25, 2007 i just cut the wires off my pads as the bit they connect to got ripped off offroading years ago. Often we get wires with pads and there is nothing to connect them to so we cut them off. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 25, 2007 Share Posted February 25, 2007 Some brake pad manufacturers give you the option of pads that have no wires. If you don't have/need/care about the wear indicator, then just cut the wires. Les. Quote Link to comment Share on other sites More sharing options...
