TJ101 Posted September 26, 2005 Share Posted September 26, 2005 Hi Guys,, a little help please,, anyone got, or know where i can get some arches for the bob as below,, They are Devon 4x4 ones, and need a set or at least the l/hand rear for a 2 door, D4x4 do not have stock thanks for any help Quote Link to comment Share on other sites More sharing options...
Niall_CSK Posted September 26, 2005 Share Posted September 26, 2005 I went down this road a couple of years back and couldn't find anything of a decent sized set specifically for the Rangie. I managed to find two items, one was genuine rubber stick ons from LR Supermarket and a set of fibregalss eyebrows from a now dfunct mob in Birmingham that attached to the wing lip. Neither were more than what I would call spats but adequate for my purposes. Over the years I have looked at quite a few that I have seen either in pictures or at shows but on enquiry they have all turned out to be modified from other sources, everything from Defenders, Discos, Nissan Patrols and even commercial vehicles. I have been told second hand that the ones supplied by Devon 4x4 are Australian made items taken from an older model Nissan Patrol. In short I think you will have to make something custom unless someone else knows better. This is all for a two door. Quote Link to comment Share on other sites More sharing options...
Budgie Posted September 27, 2005 Share Posted September 27, 2005 The ones D44 sell are made by Rangie Spares in Oz. I'm going to try & repair my rear drivers side one, after catching it on a log in Belgium , but if that fails then I'll need a new one, if I can get just the one!! Quote Link to comment Share on other sites More sharing options...
Tangoman Posted October 2, 2005 Share Posted October 2, 2005 Budgie these are easy to repair aftr having them on the rangie for several years and being a bad driver I think i have got good with fiberglass sheet and it's a strong repair. Quote Link to comment Share on other sites More sharing options...
Budgie Posted October 3, 2005 Share Posted October 3, 2005 Budgie these are easy to repair aftr having them on the rangie for several years and being a bad driver I think i have got good with fiberglass sheet and it's a strong repair. Yep, all repaired, sprayed and back on the Disco today. Most of the time was spent waiting for the resin to go off so I could get on with the next bit. I just need to T-cut the paint and you would'nt know it's been damaged. Quote Link to comment Share on other sites More sharing options...
Budgie Posted October 4, 2005 Share Posted October 4, 2005 Here you go, the repaired arch : Quote Link to comment Share on other sites More sharing options...
TJ101 Posted October 4, 2005 Author Share Posted October 4, 2005 Thanks guys,, well it looks like a repair job,, the l/h rear's in 3 bits,, problem is i only have 2 off them Will have to talk the local expert into having a look at them over a beer on Thusday night Quote Link to comment Share on other sites More sharing options...
