Defender radiators
I've bought myself a 200 Tdi Disco as an engine donor for my 2,5 n/a One Ten. When checking for radiators with room for the intercooler, I find that one for a 200 Tdi Def is frightingly expensive and that one for a 300 Tdi is a lot less so.
Can anybody explain the difference and if I can use the newer one for my upgrade together with the Disco intercooler?
Hiya Lars
i sourced one out of Paddocks when I was last over in the Uk about 18 months ago to get a larger intercooler fitted
The rad was not as it should be & so went around to Paddocks
it was a 300tdi rad (bi Flow type ) came to about GBP 108
seems to be decent quality and I have had no problems
try them as there delivery rates within the EU are good and they deliver very fast order monday delv on wed morn to frankfurt
happy trails
Abe
How about leaving your current radiator in place. Then get a larger intercooler to fit in front of it. Either an allisport os similar manufacture, or a scrap yard special.
That way you keep cash in your pocket, get a bigger rad, bigger intercooler. Then tweek the pump and the motor will go faster.....
Adrian
 Share
