FridgeFreezer Posted March 3, 2007 Share Posted March 3, 2007 Could do, but they seem to run fine once it's running so that would sort of knock that one out also if the MS isn't seeing the missing tooth on the wheel then god knows what the code is doing to try and work out when to fire what coil - it could be that without seeing the gap it won't fire all of the coils. Fingers crossed the ECU will check out OK (if not I blame the eejit who built it ) and Rog can then start to track down why he isn't seeing the gap on the trigger wheel as at the very least that can't be doing it any favours! Quote Link to comment Share on other sites More sharing options...
