roguevogue Posted September 26, 2005 Share Posted September 26, 2005 On Sunday I set out to finish modifying the inner wings on the rogue, before you know it I slipped with the grinder and cut the steel brake pipe on the inside of the wing. So, having inadvertantly started modifying the brakes I decided to kill two birds with one stone and fit 3-link along with new brake pipes, as I would have to change the flexible pipes anyway. So, this is the result so far..... I also incorporated a diff guard..... We'll see where it goes from here. Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 26, 2005 Share Posted September 26, 2005 While you've got the axle off, what are you going to put in the middle bit before you put it back on?? Are you going for a bush on the rear end of the top link or rose joint?? Cheers Steve Quote Link to comment Share on other sites More sharing options...
roguevogue Posted September 26, 2005 Author Share Posted September 26, 2005 Fitting a standard "open" diff. Couldn't possibly discuss the fine details at this stage and certainly not in public. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 26, 2005 Share Posted September 26, 2005 10mm £1/ft12mm £1.25/ft Send a PM Love the signature, and the metal work, funny all this happened whilst "the Boss" was away or is it just sheer coincidence ?? Nige Quote Link to comment Share on other sites More sharing options...
LR90 Posted September 26, 2005 Share Posted September 26, 2005 Love the signature, and the metal work, funny all this happened whilst "the Boss" was away or is it just sheer coincidence ?? Nige Hmm, thanks for pointing that out Nige. On the new server you can enter £ symbols and they come out just fine but I suspect there was a character set mismatch when we swapped servers which is why Rougue's sig looks odd. I could alter it for him but thought that might be bad form (and anyway I'm not in the market for plasma right now). And on a more tech note Rogue, why not fit a toy centre in there with some big shaft while you've got that case on the bench. Quote Link to comment Share on other sites More sharing options...
fisha Posted September 26, 2005 Share Posted September 26, 2005 Nice axle, blah blah blah blah one question.... how do you make a flat metal bench like that? what kind of metal is it? just mild steel on a hefty wooden base? how do you stop it rusting? just curious as i'm about to make a nice long bench setup in the garage and am going to be wanting a hetfy top surface to it. cheers, Donald p.s. the axle does really look good Quote Link to comment Share on other sites More sharing options...
roguevogue Posted September 27, 2005 Author Share Posted September 27, 2005 Hmm, thanks for pointing that out Nige. On the new server you can enter £ symbols and they come out just fine but I suspect there was a character set mismatch when we swapped servers which is why Rougue's sig looks odd. I could alter it for him but thought that might be bad form (and anyway I'm not in the market for plasma right now).And on a more tech note Rogue, why not fit a toy centre in there with some big shaft while you've got that case on the bench. Money, money, money. Nice axle, blah blah blah blah one question.... how do you make a flat metal bench like that? what kind of metal is it? just mild steel on a hefty wooden base? how do you stop it rusting? just curious as i'm about to make a nice long bench setup in the garage and am going to be wanting a hetfy top surface to it. cheers, Donald p.s. the axle does really look good 2x1 15mm thick steel plate on 50mm box section frame. doesn't rust because I work 9hrs a day on it. Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 27, 2005 Share Posted September 27, 2005 and anyway I'm not in the market for plasma right now hmmmmm i might be is it that nice silver stuff? Quote Link to comment Share on other sites More sharing options...
02GF74 Posted September 27, 2005 Share Posted September 27, 2005 I like the hot cross bun diff guard. I hope you welded it in true Land Rover owner fashion right over the drain plug Please tell me that is not your home workshop! Quote Link to comment Share on other sites More sharing options...
roguevogue Posted September 27, 2005 Author Share Posted September 27, 2005 I like the hot cross bun diff guard.I hope you welded it in true Land Rover owner fashion right over the drain plug Please tell me that is not your home workshop! No, missed the drain plug. No not my home workshop. Have more kit at home. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 27, 2005 Share Posted September 27, 2005 Yum ! Mo Quote Link to comment Share on other sites More sharing options...
