Petergg Posted March 3, 2007 Share Posted March 3, 2007 Do you need to excite the alternator with the same voltage as the alternator output? or could you excite a 24v with 12v? Regards Peter Quote Link to comment Share on other sites More sharing options...
simonb Posted March 3, 2007 Share Posted March 3, 2007 Do you need to excite the alternator with the same voltage as the alternator output? or could you excite a 24v with 12v?Regards Peter Needs to be the same as the battery voltage otherwise you will bu&&er the regulator. 12v on 24v is likely to result in low output voltage. Quote Link to comment Share on other sites More sharing options...
