Les Henson Posted March 9, 2007 Share Posted March 9, 2007 I was offered a 'used once only' Sealey pipe bender for £60 last night. It still looks as good as new, and wondered if anyone has any experience of these. Sealey have a good reputation (though not as good as it used to be). This is the same thing off of their website:- http://www.sealey.co.uk/PLPageBuilder.asp?...amp;cmdGo=Go%21 Les. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 9, 2007 Share Posted March 9, 2007 At that price I would buy it and 'bay it if it's no good. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 9, 2007 Author Share Posted March 9, 2007 I could do that anyway after I've finished with it Bish. A 10-ton hydraulic ram must be pretty-much the same as the next for the relatively short amount of use it'll get. Clarke benders have good rams, but rubbush formers apparently, so how do I tell if a former is ok or not? Les. Quote Link to comment Share on other sites More sharing options...
steve b Posted March 9, 2007 Share Posted March 9, 2007 Hi Les I used one of those sealey pipe benders to make my exo cage and it worked fine if you buy it use it and want to sell it i would be interested later . I did find it kinked on tight 90 bends but that could be tube quality . cheers steve Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted March 9, 2007 Share Posted March 9, 2007 I bought the same one (funnily enough for the same price!) but have not yet got round to using it. Let me know how you get on with it! Out of interest what tube did you use to build your exocage steve? Quote Link to comment Share on other sites More sharing options...
najw Posted March 9, 2007 Share Posted March 9, 2007 I built two cars using one of these. The quality of tube used is imperative, one batch I had kinked on every bend. Changed supplier, different batch and it was fine. That was Blue Band for roll cage. The formers are not a good fit, a piece of very thin ali between the tube and former solves this, but you can only use each piece a couple of times otherwise they wrinkle and the wrinkles get replicated on the tube. For 1" and similar you can get nice tight bends, for roll cage work 90 degrees is the max. HTH Quote Link to comment Share on other sites More sharing options...
steve b Posted March 9, 2007 Share Posted March 9, 2007 As it's not a competition spec cage I used what I had on the rack low spec cds about 48o/d I did find 90 bend to be the max attainable and when I ran out of old stuff the new similar spec I got hold of seemed softer i.e. small dents where the outer rollers support the tube ...like your tip using thin piece of ally najw will remember that one. Best thing OF is to get the m/c out stick a bit of tube in and have a go, getting bend centres is a bit of a practice job but if you measure and mark your bend start point or centre point you'll soon work out how the development happens cheers Steveb Quote Link to comment Share on other sites More sharing options...
Pyrover Posted March 9, 2007 Share Posted March 9, 2007 At that price I would buy it and 'bay it if it's no good. £211.44... ! What are you mad or something, my brother picked up the 16ton version of this type for new off Ebay for £90 (not Sealey though, but still works sound). Have a look for "Hydraulic pipe bender" there's loads posted at the moment. As stated these type of benders have a tendancy to kink poor quality pipe. With smaller pipe you could try filling with sand (block off ends) before bending or failing that fill with water and freeze before bending, this depends on the type of material your trying to bend though. Interesting post on the Aluminium plate though, I'll have to try that one out. HTH. Quote Link to comment Share on other sites More sharing options...
Pyrover Posted March 9, 2007 Share Posted March 9, 2007 Sorry forgot to add this. It's a tube bending guide for anyone who's interested Click. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 9, 2007 Share Posted March 9, 2007 £211.44... ! What are you mad or something, my brother picked up the 16ton version of this type for new off Ebay for £90 (not Sealey though, but still works sound). Err, no, the price is £60!! Tut tut, please read the first post thoroughly, tut. Quote Link to comment Share on other sites More sharing options...
Pyrover Posted March 9, 2007 Share Posted March 9, 2007 D'oh..! Was looking at Sealey's own price, even so I'd pay the extra and get a higher rated one as it can be turned into a half decent press (with a bit of bodging). Quote Link to comment Share on other sites More sharing options...
