OilIT Posted March 15, 2007 Share Posted March 15, 2007 Hi Can you tell me - does a propshaft off a 90 TD5 fit a 90 300tdi? - I cant see why it wouldnt - but just in case somebody knows something i dont ! Quote Link to comment Share on other sites More sharing options...
white90 Posted March 15, 2007 Share Posted March 15, 2007 rear is the same, front is wider angle but bolts straight on Quote Link to comment Share on other sites More sharing options...
OilIT Posted March 15, 2007 Author Share Posted March 15, 2007 rear is the same, front is wider angle but bolts straight on great - thanks! Quote Link to comment Share on other sites More sharing options...
cenick Posted March 17, 2007 Share Posted March 17, 2007 rear is the same, front is wider angle but bolts straight on Hi, would that be the same for a 200dti? and would a 110 front prop fit a 90 as i seen a doublecardon for sale BTW excellent forum Thanks Cenick Quote Link to comment Share on other sites More sharing options...
simonb Posted March 17, 2007 Share Posted March 17, 2007 Hi, would that be the same for a 200dti? and would a 110 front prop fit a 90 as i seen a doublecardon for saleBTW excellent forum Thanks Cenick Should do as IIRC transfer box is in the same place, its the engine which is a different place on the chassis for 200/300/Td5. 110 front prop should be the same as for a 90. Quote Link to comment Share on other sites More sharing options...
