tracengrant Posted March 16, 2007 Share Posted March 16, 2007 hi there i have a discovery 1 and the blower has just stopped working (give up the ghost) has ne1 got ne ideas on wot I should be looking for please....................... Quote Link to comment Share on other sites More sharing options...
Divster Posted March 16, 2007 Share Posted March 16, 2007 hi there i have a discovery 1 and the blower has just stopped working (give up the ghost) has ne1 got ne ideas on wot I should be looking for please....................... Firstly check the fuse. If the fuse is OK check that there is a power reaching the motor with the switch on Quote Link to comment Share on other sites More sharing options...
tracengrant Posted March 16, 2007 Author Share Posted March 16, 2007 Firstly check the fuse. If the fuse is OK check that there is a power reaching the motor with the switch on thank you it was working fine i put it on worked for approx 3 secs and then just stopped. How do I check power getting to it. sorry for all the questions........ Quote Link to comment Share on other sites More sharing options...
Divster Posted March 16, 2007 Share Posted March 16, 2007 thank you it was working fine i put it on worked for approx 3 secs and then just stopped. How do I check power getting to it. sorry for all the questions........ You will need to attach a multimeter to the terminals on the heater. There should be a 12v feed direct from the fuse board (purple and green I think) and two other wires (grey with a trace colour, but I can't remember which ones which) that control the speed of the fan. These two terminals should show a decent feed when the switch is in the on position. Quote Link to comment Share on other sites More sharing options...
