Lars L Posted March 23, 2007 Share Posted March 23, 2007 I took my 2,5 NAD out after just removing the radiator. After all, there are only a few bolts to get it out. The front panel was still there, one of the cagenuts is just spinning, see. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted March 23, 2007 Share Posted March 23, 2007 I didn't take the rad out to do mine. There's loads of space there, just make sure your engine lift is capable of lifting over the rad. Mine only just made it, scraping the sump on the front panel as I lifted it over. Safety point When you do separate the engine/box the engine will "spring" free. So be aware that if you have fingers in the way it'll hurt Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted March 23, 2007 Author Share Posted March 23, 2007 Thanks very much Walfy. By coincidence, the parts have just arrived and I note that the seal has been supplied is one from Allmakes with a green aluminium ring around it so I have no idea whether this is going to present problems or not -I guess only time will tell. I have got a new clutch assembly to do at the same time as well as the fork and thrust bearing. I have never taken a TDI engine out before so it's going to be a bit of a learning process. I presumed that the turbo can stay on and that the exhaust can be separated at the top of the downpipe without needing to remove the manifold from the block. The rest hopefully will be fairly straightforward! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted March 23, 2007 Share Posted March 23, 2007 Yes just break it at the downpipe. Don't forget the cables on the starter motor, Cables from alt, Fuel lines at the FIP, Multi plug at the bulkhead, Easier to drop the PAS pump complete saves bleeding, water piper at heater box I just started at 1 corner of the engine bay and worked round unbolting/unclipping everthing. When I first did it I wrote a list of all the bits undone. Then when it goes back together I just ticked off the list. Now I don't use the list I've done it that many times If you need advice at all just ask Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted March 23, 2007 Author Share Posted March 23, 2007 Thanks again and I'm sure that you be hearing the last of this.................. Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2007 Share Posted March 23, 2007 Which clutch friction plate have you got? the 130 Valeo with 8 springs in it is the best IMHO Quote Link to comment Share on other sites More sharing options...
