HoSS Posted March 18, 2007 Share Posted March 18, 2007 Since doing the auto box conversion on the V8 3.5, I have had a clicky/knock sound in time with engine revs & louder the more load/pedal is applied. doesn;t do it if reved in neutral. I know since the conversion i have picked up a bit of a shudder as the revs drop below 1500 in neutral, so the drive plate is prob not in perfect balance. I can't se how this is the autobox, would they make that kind of noise? (bear in mind its a 'new' ashcroft rebuild) But i'm begining to wonder if a main / big end bearing problem is coming on? any ideas? Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted March 18, 2007 Share Posted March 18, 2007 Sounds more like a hydraulic lifter that has expired or got some sh!t in it ………… These guys will make real loud worrying noises if not pumped up. What is the oil pressure like ? BTW: the bottom end on the V8 is fairly bomb proof ……….. but the top end wears real bad and this is hidden by virtue of the design …………. Ian Quote Link to comment Share on other sites More sharing options...
HoSS Posted March 18, 2007 Author Share Posted March 18, 2007 Sounds more like a hydraulic lifter that has expired or got some sh!t in it …………These guys will make real loud worrying noises if not pumped up. What is the oil pressure like ? BTW: the bottom end on the V8 is fairly bomb proof ……….. but the top end wears real bad and this is hidden by virtue of the design …………. Ian It had new (genuine) cam shaft, lifters & chain about 500km ago. I did have an issue with low oil pressure when warm, but have just fitted a new pump base & the pressure is about 30-50 psi now. Also i suspect the cam area stuuf would make noise with any load level? Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted March 19, 2007 Share Posted March 19, 2007 With 30psi oil pressure on a hot engine it is very doubtful that the mains and big ends are worn to the point of knocking...............if this was not happening before the g/box change, then it maybe the torque converter / flex plate may be the culprit. Do you still need a fuel / spark map ? ............. ping me an email Ian Quote Link to comment Share on other sites More sharing options...
HoSS Posted March 20, 2007 Author Share Posted March 20, 2007 With 30psi oil pressure on a hot engine it is very doubtful that the mains and big ends are worn to the point of knocking...............if this was not happening before the g/box change, then it maybe the torque converter / flex plate may be the culprit.Do you still need a fuel / spark map ? ............. ping me an email Ian mmm i suspect the drive/flex plate balance beacuse of the shudder when engine revs down. just not sure how to balance it situ. My fuel map is pretty good now. I invested in the Innovate wide band O2 sensor, tuned up nicely. Spark map, i need. Did a lot of research & then got very confused about what is right PMd u my email, cheers. Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted March 20, 2007 Share Posted March 20, 2007 I recall having a similar problem when I converted my V8 to an autobox and it turned out that one of the crank shaft fixing studs had worked loose inside the torque converter. Mine made a hell of a racket so I don't know if it's exactly the same as you are experiencing but perhaps something worth considering. Quote Link to comment Share on other sites More sharing options...
TomG Posted March 20, 2007 Share Posted March 20, 2007 mmm i suspect the drive/flex plate balance beacuse of the shudder when engine revs down. just not sure how to balance it situ.My fuel map is pretty good now. I invested in the Innovate wide band O2 sensor, tuned up nicely. Spark map, i need. Did a lot of research & then got very confused about what is right PMd u my email, cheers. I can post my spark map up this evening if it's any use? I think it's fairly safe and from what i understand roughly matches the stock distributor advance. Am running the Innovate wide band too (recently fitted it) I'd be interested in your target AFR map if you have it, can post my guess at it too. Can I check with the mods if it's acceptable (within forum rules) to upload exported table files or the MSQ as an attachment? Cheers Quote Link to comment Share on other sites More sharing options...
HoSS Posted March 20, 2007 Author Share Posted March 20, 2007 I recall having a similar problem when I converted my V8 to an autobox and it turned out that one of the crank shaft fixing studs had worked loose inside the torque converter. Mine made a hell of a racket so I don't know if it's exactly the same as you are experiencing but perhaps something worth considering. You mean the flexplate to TC bolts, or really inside the TC? I can post my spark map up this evening if it's any use? I think it's fairly safe and from what i understand roughly matches the stock distributor advance.Am running the Innovate wide band too (recently fitted it) I'd be interested in your target AFR map if you have it, can post my guess at it too. Can I check with the mods if it's acceptable (within forum rules) to upload exported table files or the MSQ as an attachment? - Thanks. - Will do, as soon as laptop available. - Dont see why not. theres nothing viral or copyright about it. Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted March 20, 2007 Share Posted March 20, 2007 You mean the flexplate to TC bolts, or really inside the TC?- Thanks. - Will do, as soon as laptop available. - Dont see why not. theres nothing viral or copyright about it. Sorry - bad english. I mean the ones that hold the flex plate. Its been a while!! Quote Link to comment Share on other sites More sharing options...
HoSS Posted March 20, 2007 Author Share Posted March 20, 2007 Sorry - bad english. I mean the ones that hold the flex plate. Its been a while!! ah non, ca c'est bien vissee. J'ai controle. Quote Link to comment Share on other sites More sharing options...
TomG Posted March 20, 2007 Share Posted March 20, 2007 Here's my current settings: Fraid the forum editor wouldn't let me upload the .vex files (file type not allowed) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 20, 2007 Share Posted March 20, 2007 If you open the .VEX file in Notepad and just copy/paste into a post you can do the reverse at the other end and save as .VEX, they are just stored as text IIRC. Would be good to get a collection of fuel & spark maps for landies here. Quote Link to comment Share on other sites More sharing options...
TomG Posted March 20, 2007 Share Posted March 20, 2007 Didn't want to flood the forum but found a use for the forum's Codebox thingy B) AFR Table: EVEME 1.0 UserRev: 1.00 UserComment: Date: 03-20-2007 Time: 20:47 Page 0 Scale 0.039200 Translate 255.000000 VE Table RPM Range [ 8] [ 0] = 12 [ 1] = 25 [ 2] = 30 [ 3] = 35 [ 4] = 40 [ 5] = 45 [ 6] = 50 [ 7] = 58 VE Table Load Range (MAP) [ 8] [ 0] = 15 [ 1] = 25 [ 2] = 45 [ 3] = 60 [ 4] = 70 [ 5] = 80 [ 6] = 90 [ 7] = 100 VE Table [ 8][ 8] [ 0] [ 1] [ 2] [ 3] [ 4] [ 5] [ 6] [ 7] [ 0] = 120 120 120 120 120 120 120 120 [ 1] = 120 120 120 120 120 120 120 120 [ 2] = 120 120 120 120 120 115 102 77 [ 3] = 120 120 120 120 120 102 77 77 [ 4] = 102 102 102 102 102 77 77 77 [ 5] = 77 77 77 77 77 77 77 77 [ 6] = 64 64 64 64 64 64 64 64 [ 7] = 64 64 64 64 64 64 64 64 Spark Table EVEME 1.0 UserRev: 1.00 UserComment: Date: 03-20-2007 Time: 20:47 Page 0 Scale 0.352000 Translate -28.400000 VE Table RPM Range [12] [ 0] = 5 [ 1] = 8 [ 2] = 10 [ 3] = 15 [ 4] = 20 [ 5] = 25 [ 6] = 28 [ 7] = 30 [ 8] = 35 [ 9] = 42 [ 10] = 50 [ 11] = 60 VE Table Load Range (MAP) [12] [ 0] = 20 [ 1] = 25 [ 2] = 30 [ 3] = 35 [ 4] = 40 [ 5] = 45 [ 6] = 50 [ 7] = 55 [ 8] = 60 [ 9] = 70 [ 10] = 80 [ 11] = 100 VE Table [ 12][ 12] [ 0] [ 1] [ 2] [ 3] [ 4] [ 5] [ 6] [ 7] [ 8] [ 9] [ 10] [ 11] [ 0] = 82 122 116 125 134 153 153 153 153 153 153 153 [ 1] = 77 77 77 102 119 145 145 145 145 145 145 145 [ 2] = 77 77 77 99 119 139 139 139 139 139 139 139 [ 3] = 74 74 74 102 119 134 139 139 139 139 136 139 [ 4] = 74 74 74 105 122 128 139 139 139 139 139 139 [ 5] = 74 74 77 102 122 128 136 136 136 136 136 139 [ 6] = 71 71 80 102 122 128 128 134 134 134 134 139 [ 7] = 62 62 71 99 116 125 125 131 134 134 134 134 [ 8] = 57 57 80 94 111 122 122 125 128 128 134 134 [ 9] = 57 57 80 91 111 122 122 125 128 128 134 134 [ 10] = 51 51 77 85 111 122 122 125 128 125 125 125 [ 11] = 51 51 77 85 105 119 119 119 119 119 119 119 Quote Link to comment Share on other sites More sharing options...
