Tiger Posted March 19, 2007 Share Posted March 19, 2007 Right further to my last post I'm really struggling with a PAS pipe. This is my own fault as I've mixed bits up. I need a pressure return power steering pipe to connect my pump (etc9077) to a 4 bolt box. I now have a 2 pipes and niether fit. Does a pipe even exist that will work with this did a 4 bolt adwest box ever connect to a PAS pump with a banjo fitting? Help as this is driving mental and I've just been quote £150 to have a pipe made. Techniacl Details bit Box is 4 bolt adwest with metric fittings Pump is a ETC9077 with 5/8" Bajo fitting Pipe one fits Bajo end but not box (part numbers NTC6731) Pipe two is orginal and fits pump but is imperial (orginally went into a 3 bolt adwest box) One slution maybe to use the old pipe can you get imperial to metric union adpaters? Help! Quote Link to comment Share on other sites More sharing options...
Tiger Posted March 19, 2007 Author Share Posted March 19, 2007 right I think I've found the bit I need to make my pipe fit. Looks like a little adapter that allows a normal metric union fit to the banjo. See image, where do I get this from without buying a new pump???? Quote Link to comment Share on other sites More sharing options...
white90 Posted March 19, 2007 Share Posted March 19, 2007 Pirtek look them up in Yellow pages they'll make any type pipe req Quote Link to comment Share on other sites More sharing options...
Tonk Posted March 19, 2007 Share Posted March 19, 2007 a metric 4 bolt v8 efi range rover pas pipe will fit what you want it to, banjo fitting one end to metric union fitting the other, a little shorter than is ideal but will fit Quote Link to comment Share on other sites More sharing options...
Tonk Posted March 19, 2007 Share Posted March 19, 2007 scrub that^^^^^^^^^^^^^^^ sorry, i haven't had enough drugs yet early defender pipe had a banjo fitting on end so fits straight to your pump and has metric fitting box end, or what u've pictured there is 200tdi type pump. Quote Link to comment Share on other sites More sharing options...
Pyrover Posted March 19, 2007 Share Posted March 19, 2007 I also had a mare fitting PAS to my 110 (see here), I eventually fitted the Adwest 4 bolt box with a TDi ETC9077 pump. The pump to steering box hose I used was NTC5001 (banjo one end, threaded the other). Edited: D'oh! just spotted it's your original thread (I think I'll be needing some of those drugs as well ) Quote Link to comment Share on other sites More sharing options...
Tiger Posted March 19, 2007 Author Share Posted March 19, 2007 The pump to steering box hose I used was NTC5001 (banjo one end, threaded the other). Tried to get that but have been told that its been superseeded, I could have just been fobbed off however Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 19, 2007 Share Posted March 19, 2007 Tiger Best advice I can give is Yellow Pages. Look for a hydraulic hose company/person. They should make up what you need. I tried Pirtec up here. Frankly they didn't know what I was on about whehn I wanted a pipe making. My ten bobs worth mike FOAK I can cause trouble in an empty house !!! Quote Link to comment Share on other sites More sharing options...
Pyrover Posted March 19, 2007 Share Posted March 19, 2007 Just been in touch with Brookwells in Plymouth (free internet calls... don't you just love them ) to see how hard they are to source and the bloke says he can get hold of them for around £30, might be worth giving them a bell. HTH. Quote Link to comment Share on other sites More sharing options...
Martin90 Posted March 20, 2007 Share Posted March 20, 2007 My Mazda 35SL powered Rangie has the two seperate hoses cut, slid over what looks like 15mm copper pipe, and jubilee clipped in place. Works great and no leaks. Martin Quote Link to comment Share on other sites More sharing options...
JST Posted March 20, 2007 Share Posted March 20, 2007 Martin - MOT man happy with that on the HP side? are you? Quote Link to comment Share on other sites More sharing options...
Kim Horsevad Posted March 22, 2007 Share Posted March 22, 2007 My Mazda 35SL powered Rangie has the two seperate hoses cut, slid over what looks like 15mm copper pipe, and jubilee clipped in place. Works great and no leaks.Martin Sorry if I sound rude, but if its on the pressure side that is a disaster waiting to happen. If you have ever seen the effects of a high pressure hydraulic hose fracturing you would want to get a proper hose made up.... ASAP! Quote Link to comment Share on other sites More sharing options...
