Daan Posted March 19, 2007 Share Posted March 19, 2007 I am planning on making my own winch fairlead to use with plasma. What diameter bar is commonly used? I am thinking to go bigger than standard to reduce bendingstresses on the rope, but another thought is that there is more contact area and therefore more heat build up. I know Jez has 2" diameter fairleads, but It hasn't been used yet, or has it Jez? Another thought I had is not to bother with it and have good old rollers, like I always had. no heat at all, provided they rotate freely. Lots of questions already, answers Anyone? daan Quote Link to comment Share on other sites More sharing options...
dollythelw Posted March 19, 2007 Share Posted March 19, 2007 Not used in anger yet but my friend has been using the same system for about 3 years now Daan - he had no real problems, theres plenty to sink heat with that design could you re-work the roller design to have waisted rollers? then there isnt the pinch point in the corner? just an idea? Quote Link to comment Share on other sites More sharing options...
Daan Posted March 19, 2007 Author Share Posted March 19, 2007 That could work, but involves asking favours to someone with a lathe-and I have many more like that in front of me at the mo. I am now more thinking about stainless rollers with ballbearings. This to reduce drag, and in case the rope does start sliding, you have a stainless fairlead. I am still aksing myself the question why, since we introduced plasma rope which is not very abrasion resisting, we all are replacing rollers for a solid guide. My rear winch is going to have a guide like this for reasons of compactness, but for the front, I am still keen on the good old rolling resistance rather than dragging resistance. Daan Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted March 19, 2007 Share Posted March 19, 2007 I normally use 60x20 flat bar then mill a slot in it and chamfer the edges with one of astro al's loverly radial burrs in my die grinder. Quote Link to comment Share on other sites More sharing options...
