hkkri Posted March 20, 2007 Share Posted March 20, 2007 Hi I like to tray to make me some rock sliders and I ned some help. and the size of the metal I do not knowe? so far I have come is 153cm L 6.5cm H 4.5cm B It is a 3 door disco from 1992. sorry a but my english Quote Link to comment Share on other sites More sharing options...
russ3120 Posted March 20, 2007 Share Posted March 20, 2007 thought about doing this my self 100mm x 50mm heavy duty box section steel (3mm wall thickness) some 20mm steel bar bent and welded on as tree deflector some steel tube fitted and welded into the box section. just need to find the time. Russ Quote Link to comment Share on other sites More sharing options...
hkkri Posted March 20, 2007 Author Share Posted March 20, 2007 thought about doing this my self100mm x 50mm heavy duty box section steel (3mm wall thickness) some 20mm steel bar bent and welded on as tree deflector some steel tube fitted and welded into the box section. just need to find the time. Russ Hi and thanks Russ Then I knowe what to do Quote Link to comment Share on other sites More sharing options...
LS26 Posted March 20, 2007 Share Posted March 20, 2007 Having put 100x50 on my RRC - I reckon you'd be better off with 100x60 (it would fit better in place of the original sill) (Edit: Ooh - sorry, maybe I assume too much? Is the Disco sill the same width as the RRC?) Rog Quote Link to comment Share on other sites More sharing options...
hkkri Posted March 21, 2007 Author Share Posted March 21, 2007 Having put 100x50 on my RRC - I reckon you'd be better off with 100x60 (it would fit better in place of the original sill)(Edit: Ooh - sorry, maybe I assume too much? Is the Disco sill the same width as the RRC?) Rog Hi Rog mybe you have it right but I knowe the clas/RRC and disco has the same cassis. and I will see what I can get hold of 100/50 ore 100/60. thanks Rog Quote Link to comment Share on other sites More sharing options...
streaky Posted March 21, 2007 Share Posted March 21, 2007 The problem to overcome in making sliders for a Disco is the camberd sill line. I've looked at doing it, but making them from pre-formed steel section steel was not the best option. I saw a guy make a set for his Discovery by mounting them behind the plastic sill. This way he kept the astetic looks of the camberd sills....but the box section behind the sill was used as the rock slider. He didn't have jacking points on them either which I think are a great benefit to have on a Discovery. If you are not so worried about keeping the lines of the Discovery sills...then the above option of Russ would be the way to go. Regards. S Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted March 21, 2007 Share Posted March 21, 2007 Why not check out http://www.discoweb.org/ and go to the TECH section. Loads of info on making your own sliders, bumpers etc. Very good site IMHO Quote Link to comment Share on other sites More sharing options...
hkkri Posted March 21, 2007 Author Share Posted March 21, 2007 The problem to overcome in making sliders for a Disco is the camberd sill line. I've looked at doing it, but making them from pre-formed steel section steel was not the best option.I saw a guy make a set for his Discovery by mounting them behind the plastic sill. This way he kept the astetic looks of the camberd sills....but the box section behind the sill was used as the rock slider. He didn't have jacking points on them either which I think are a great benefit to have on a Discovery. If you are not so worried about keeping the lines of the Discovery sills...then the above option of Russ would be the way to go. Regards. S Hi streaky I have not the plastic sill one the dico it is strait down from door sill. regards Hans Quote Link to comment Share on other sites More sharing options...
hkkri Posted March 21, 2007 Author Share Posted March 21, 2007 Why not check outhttp://www.discoweb.org/ and go to the TECH section. Loads of info on making your own sliders, bumpers etc. Very good site IMHO hi good info thanks to Orgasmic Farmer regards Hans Quote Link to comment Share on other sites More sharing options...
waveydave Posted March 24, 2007 Share Posted March 24, 2007 Made a set for mine with 100x50 box. With some time taken and a little jiggling you can get away with using stright box section with out it looking too odd. Quote Link to comment Share on other sites More sharing options...
LR90 Posted March 24, 2007 Share Posted March 24, 2007 Very nice but what's the vehicle in the background? Quote Link to comment Share on other sites More sharing options...
waveydave Posted March 24, 2007 Share Posted March 24, 2007 Strange Rover Comp Safari mota Quote Link to comment Share on other sites More sharing options...
hkkri Posted March 25, 2007 Author Share Posted March 25, 2007 Made a set for mine with 100x50 box.With some time taken and a little jiggling you can get away with using stright box section with out it looking too odd. Hi waveydave It looks good and your cars is nice. I will take some pic. off the rocksliders and put it one here. Quote Link to comment Share on other sites More sharing options...
simon_s Posted March 29, 2007 Share Posted March 29, 2007 Strange Rover Comp Safari mota Chris n' Craigs isn't it? Quote Link to comment Share on other sites More sharing options...
hkkri Posted April 12, 2007 Author Share Posted April 12, 2007 Hi a update on the rock sliders it is so long I have come it looks ok . Quote Link to comment Share on other sites More sharing options...
gav- Posted April 12, 2007 Share Posted April 12, 2007 i have replaced my sills with 3.6mmx 100x60 section. Not going to worry about rock sliders now!!!!! Quote Link to comment Share on other sites More sharing options...
