Abe Posted March 21, 2007 Share Posted March 21, 2007 Just a quick Enquiry Iam thinking about buying a Becker Traffic Pro 4765 navigation unit for installation into a 2001 P38 Has anyone already one installed into theirs / has one already fitted? how do you rate them? The unit i have my eye on is a LR branded one & thus I "assume" it would be compatable with the CD changer already fitted to the std RR Hamon kardon header unit. A friend had one installed into of all things a a ford transit and to find the way its not too bad. my aim with the old type unit is so i can utilise the std DIN radio slot. appreciate any feedback thanks & happy Trials Abe Quote Link to comment Share on other sites More sharing options...
Shackleton Posted March 31, 2007 Share Posted March 31, 2007 Don't have direct experience but I just project managed the 100% restoration of one of my directors '85 Benz SL's and I spec'd the new Becker Mexico retro remake. It's got sat nav built in. The whole unit is simply superb, as in I knew it was going to be nice but reading the specs and actually using it are two different matters. Not bloody cheap though. The sat nav is good but does take a little getting used to. The stand alone Garmin units are easier to figure out being touch screen etc but the Becker is just as easy once you've properly learnt it's ways. Oh and don't assume about compatibility, call a becker agent, it's the only way. For instance this Mexico will only talk to EITHER an iPod OR a CD changer but not both. Sounds odd and again not directly related but it goes some way to showing that something that may seem common sense might no work out. Quote Link to comment Share on other sites More sharing options...
Abe Posted April 2, 2007 Author Share Posted April 2, 2007 many thanks for the reply I wanted to put one in as I didnt want be asred with going for a original RR p38 system as thery are old tech anyways I thought about the becker as a mate had one in his transit and as they fit the standard slot & dont rely on a separate CD drive - thought the instalation would be straghtforward as it would just be a case of fitting the GPS antena and if necessary the speedo transmitter the aim was just to get something to shoul me directions when needed Thinking about it - it would mean lossing the RR orig H/K unit which is good so i might be temted to just go fo a Tom Tom or one of the occasional usage units never-the less thanks for the info have a nice one & happy trails Abe Quote Link to comment Share on other sites More sharing options...
