Extra Guages
Peterla
I am looking at installing a EGT, Boost and voltage gauge in my 200 Tdi.
Can any one help me with where I can get a console to add to my dash.
Some thing that looks like it is suppost to be there would be perfered.
Thanks
Pete
Thanks
Pete
Kev Baldwin (on here) sells a Defender centre console for 200/300tdi, similar to the TD5, through his company Mudstuff.co.uk. Excellent product and not expensive.
John
John
I'm currently fitting one of them in my Disco 300. It fits right over the centre tray.
Any pic's of this Expat ?
Can you post some when done ?
Cheers
TPK
Doing the pics today and tomorrow, but will be posted after the 6th April (don't ask... :rolleyes: )
so far so good in term of install.
The base plate is only 6mm wider than the tray. Also I did not want to completely block the vent (radio one).
So plate is resting at front of the dash, goes over the tray and 1/2 cover the radio vent
installation so far:
- removed rubber mat from tray
- drilled hole in the tray area (more towards back of tray and big enough)
- drilled two 5mm holes in plate and tray to put machine bolts
- you need to fit the bolts (5x40) from the inside out and the nuts over the plate (otherwise you cannot refit the radio) - big hands are not very useful...
- ran my wires (spread them in the hole and leave some slack... as when you fit the radio back on it will be a close fit)
then it's the standard installation of switches, gauges....
I have to say that it looks very neat...
Hope it helps
Xavier
  • 2 weeks later...
