jonmcghee Posted March 24, 2007 Share Posted March 24, 2007 hi all just a quick question need to order new swivel seals for disco but there are two sizes 12.5 and 8 mm where do you take the mesurments from to sort out which one thanks in advance Quote Link to comment Share on other sites More sharing options...
DiscoClax Posted March 27, 2007 Share Posted March 27, 2007 Is it a Disco 1 or 2 (or 3?) I think all of the D1s had the same seal (common to Rangie Classic as well), but I could be wrong. The EPC shows one seal for all D1s '89-'98 (LR p/n FTC3401), and mentions "9mm" in the part descriptor. Check out Item 11 in the attached screen dump. Hope this helps in some way Quote Link to comment Share on other sites More sharing options...
jonmcghee Posted March 27, 2007 Author Share Posted March 27, 2007 its a disco 1 paddock list the two 8 & 12.5 i emailed them and they are not sure ether how you take the mesurment. so i will order one of each by the looks of it and see which one fits Quote Link to comment Share on other sites More sharing options...
DiscoClax Posted March 27, 2007 Share Posted March 27, 2007 I've just measured the old one I replaced a few days ago. It's about 8mm thick (axially) and 18mm wide (radially). From that I'd say that the measurements you quoted are axial thicknesses and you need the 8mm one. Best of luck P.S. They cost over AU$30 each here (GBP12) non-gen, hopefully a bit cheaper in the UK? P.P.S. Check out the alternative swivel seal replacement method by Les in the tech archives. Could save you some time. That's the way I did mine, but I botched it, so take your time if you do it this way and clean the area thoroughly before starting. Quote Link to comment Share on other sites More sharing options...
