Parts guru required - What's the thread?
FridgeFreezer
hi IIRC it's m12 metric fine can't give you tpi but pretty sure it's metric fine .... I guess you have the series pedal box/ m/cyl I think you could use later mastercyl and change the pushrod ?? then use a defender/disco pipe ?
How far off are you to finishing your 109 then?
109 csw ....the best land rover ever!
cheers
steveb :)
So looks like M12F is the top candidate, next question: is it likely to be a standard fitting stocked by a car parts place?
B)-->
QUOTE(steve b @ Mar 25 2007, 07:41 PM) <{POST_SNAPBACK}>
Not too far, hopefully by the end of the week I'll be really close to done (watch now as it rains non-stop all week <_< )
you've got 303 volvo portal's on your 109 haven't you? what sort of gearing ratio,s do they have in comparison to the mog 404's (still haven't got mine home yet - soon tho)?
It's always a real boost when your project is close to going on the road ( they're rarely finished ..mine isn't :P ) so press on dude the end is in sight
cheers
steveb
