kiall Posted March 27, 2007 Share Posted March 27, 2007 hey as u might know ive got a new gearbox in my defender 110 lt77 and i get get the gearlinkage to get 5th gear , is theier any guides to set them up Quote Link to comment Share on other sites More sharing options...
western Posted March 27, 2007 Share Posted March 27, 2007 This should help ------------- welcome to LR4x4.com Quote Link to comment Share on other sites More sharing options...
kiall Posted March 27, 2007 Author Share Posted March 27, 2007 i cant even feel 5th gear with that adjust screw fully out and my gear lever springs 1 to 2 unlike most are 3 to4 Quote Link to comment Share on other sites More sharing options...
Tonk Posted March 28, 2007 Share Posted March 28, 2007 i take it you've used your old shifters onto a recon/new gearbox? should be already close enough to get all gears, when fitting the shifters did you line the roller shifter part into the C shaped shifter properly when bolting onto the gearbox? it sounds as if it might be to one side of it. Quote Link to comment Share on other sites More sharing options...
kiall Posted March 28, 2007 Author Share Posted March 28, 2007 i take it you've used your old shifters onto a recon/new gearbox?should be already close enough to get all gears, when fitting the shifters did you line the roller shifter part into the C shaped shifter properly when bolting onto the gearbox? it sounds as if it might be to one side of it. i didnt do it but ai collegue at work done it and he might of get what u have said wrong which all that am feeling kind to points to your idea do u have any pictures or diagrams of what goes where thanks kiall Quote Link to comment Share on other sites More sharing options...
western Posted March 28, 2007 Share Posted March 28, 2007 Maybe the Bias spring needs setting up correctly --------------------- Quote Link to comment Share on other sites More sharing options...
kiall Posted March 28, 2007 Author Share Posted March 28, 2007 i cant select 5th witht eh gear lever removed using a 1/2 " extension in it , ill work it out just am doing bit by bit after work so am just trying to save a little time Quote Link to comment Share on other sites More sharing options...
Tonk Posted March 29, 2007 Share Posted March 29, 2007 if you can get 5th like that then it sounds as if its all down to adjustment rather than something wrongly put together Quote Link to comment Share on other sites More sharing options...
kiall Posted March 29, 2007 Author Share Posted March 29, 2007 if you can get 5th like that then it sounds as if its all down to adjustment rather than something wrongly put together i can't get 5th Quote Link to comment Share on other sites More sharing options...
