Goldie Posted March 30, 2007 Share Posted March 30, 2007 On my 90 V8, when my friend removed the fule cap, he said that his 110 V8 has like a sunken filter in there, so while filling no carp gets in... Is this a standard item..? If so where do I get one and what is it called?? Cheers Carl.. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 30, 2007 Share Posted March 30, 2007 Actually it's a built in funnel for filling fron jerry cans. I take mine out to fill from a pump. Available from your dealer I have "tube" listed in my invoices LNTC2655 Check that one as I'm not sure it's correct. Around about 30 quidish. mike I can cause trouble in an empty house Quote Link to comment Share on other sites More sharing options...
Goldie Posted March 30, 2007 Author Share Posted March 30, 2007 Thats brill, thanks for that..!! Quote Link to comment Share on other sites More sharing options...
western Posted March 30, 2007 Share Posted March 30, 2007 Should be NTC2655, for filling from fuel cans, lift & twist to engage the pin in the standard filler tube, the inner tube will then stay in place while filling from a can, it should come with a short chain attached to anchor the filler cap to the tube to stop the cap getting dirt/grit in it. check ebay as I got mine off there. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted March 30, 2007 Share Posted March 30, 2007 Dead handy too, got one on my Tdi 90, has anyone changed the filler on a Td5 to the early Tdi-Td type? (so one can have this filler jobbie), as the Td5 one is pants. OK, you can use a jerrycan spout, but they take ages to pour, i can't see that the Tdi type would cause the Td5 fuel system any harm?? Quote Link to comment Share on other sites More sharing options...
