Weber Carb fitted....
Guest MJG
... to a SeriesIII. I understood std meant Solex or Zenith.
Any idea on here which screw does what????
PS
Back in my Mini days... Weber = high fuel comsumption..... seems the same now!!!!
PS
I would get around 21 mpg with my 34 ICH, and 19 with my 32/34 DMTL. What screw
on what carb?
on what carb?
Will get back to you - not sure what model to be honest.
Pretty sure getting no where near 21mpg - of course I wasn't expecting good fuel consumption from a s3 that's not why I bought it, but would like to get it better than it is if I am going to keep the petrol engine and not replace it with the a diesel.
on what carb?
Had a look while fitting new HT leads this morning. Its 34 ICH, so I am defo down on what you were getting.
I no longer have mine on as I have a VW Diesel in it now, but I will dig it out of the pile of Rover parts in the garage, have a look at the screws, and let you know. Have you checked your plugs to make sure it is jetted right? I live at 7400' and I think I had to run a 150 main. It had a 165 in it when I got the Rover. To be fair, I did also have 9:1 comp and a header in place of the worthless cracked cast exhaust, so both may have helped mileage a bit too.
Well, mine is quite burried. But from what I remember the screw near the base towards the front, is the idle mixture. The ones towards the bulkhead are the idle speed and idle speed for the choke. There is a brass plug with a slot towards the valve cover. The idle jet is behind it, so if it won't idle, that jet needs cleaning.
Many thanks
