bluboy Posted March 31, 2007 Share Posted March 31, 2007 I own a 96 300tdi Would someone please tell me what this is? I found it on top of the engine block when I took the rubber cover off. The tube leading to the connector has a crack in it. Do I need to replace it. What does it do? Quote Link to comment Share on other sites More sharing options...
RRX Posted March 31, 2007 Share Posted March 31, 2007 Temperature sensor i think, part of the egr system to tell it when the engine is up to temp Quote Link to comment Share on other sites More sharing options...
bluboy Posted March 31, 2007 Author Share Posted March 31, 2007 Temperature sensor i think, part of the egr system to tell it when the engine is up to temp Thanks for the swift response. I couldn't figure it out. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted April 1, 2007 Share Posted April 1, 2007 Non-egr engines just have a bolt in there. It is a handy place to fit another thermocouple if required. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 1, 2007 Share Posted April 1, 2007 The 'tube' you mention is just the shroud of the wire. No need to replace it, a bit of insulating tape would be a good repair. Les. Quote Link to comment Share on other sites More sharing options...
