200tdi steering pump return and feed - winch plumbing !!
Hi
I am obviously being thick here, but i am trying to plumb in my milemarker, and wondering which is the feed and which is the return on the steering system....
Any advice much appreciated !
jerry
I dont have a tdi pump at hand,but it should be fairly simple.
The supply/low pressure hose will come directly from the reservoir,is usually a slightly larger pipe,and on most pumps pushes onto a spigot on the pump,and is held on with a jubilee clip.
The output/high pressure hose goes to the steering box,and is usually smaller diameter,always with a high pressure crimped on threaded union.
Hope this helps. Jerry.
great - thanks - am now all hydraulic'ed up !!
