dees Posted April 3, 2007 Share Posted April 3, 2007 Hi folks, my first post here, I've been lurking for a bit, but now I have a question hopefully someone clever can answer. I am slowly building a Rangie based hybrid tht originally had a 3.5 V8 and LT95. I want five speeds, so here's the question. Would an LT77 or R380 from a Disco or Defender drop straight into the rangie chassis or are input shaft lengths different? Am I destined to look only at Range Rovers for 'boxes?? Ta for any assistance/info rendered Dees Quote Link to comment Share on other sites More sharing options...
nickm Posted April 3, 2007 Share Posted April 3, 2007 Hi folks, my first post here, I've been lurking for a bit, but now I have a question hopefully someone clever can answer. I am slowly building a Rangie based hybrid tht originally had a 3.5 V8 and LT95. I want five speeds, so here's the question. Would an LT77 or R380 from a Disco or Defender drop straight into the rangie chassis or are input shaft lengths different? Am I destined to look only at Range Rovers for 'boxes?? Ta for any assistance/info rendered Dees the shaft on a v8 5spd is longer than the diesel 1 not sure if its just the long stick boxes that were on the v8 4 spd boxes are stronger than the 5spd u could fit and o/d Quote Link to comment Share on other sites More sharing options...
simonb Posted April 3, 2007 Share Posted April 3, 2007 IIRC Disco and Defender Tdi have different length bell housings and hence input shafts. The shifter mechanism is different and I don't think its easy to swap. So, u r better looking for a Disco box as that should be similar to a Rangie...if you get a one from a V8 Disco.. Quote Link to comment Share on other sites More sharing options...
ashtrans Posted April 3, 2007 Share Posted April 3, 2007 Hi, if you are removing the LT95 the best 5 speed box to replace it with is the V8, long stick, the short stick will not fit the tunnel very well and it will need to be chopped a bit to fit but they are more readily available, you have a few options here depending on what you want to spend : the cheapest will be to get a early V8 long stick LT77 from about a 1985 RR classic, this is the type 52A suffix D LT77, next is to find a later suffix G or H LT77 type 60 or 61A which is the same as the 52A but stronger strongest is to fit a R 380 suffix L, again a V8 long stick version, or if you don't fancy a LT77 or R 380 you can always fit a Santana LT85, strong but clunky, whichever option you go for you will also need : the V8 bellhousing to go with the above box the LT230 transfer case mounts linkages clutch hope this helps, feel free to give me a call if you need any further info, Dave Ashcroft Quote Link to comment Share on other sites More sharing options...
