western Posted April 4, 2007 Share Posted April 4, 2007 I'm after some photo's of the subject mounting/bracket, as fitted to a 2.5TD engined 110, need to see where the gearbox bracket bolts to & the route of the exhaust pipe. reason -- the bracket on mine is broken & I can't figure out how it's meant to fit together, got all the bits & new bracket/rubber bushes. cheers in anticipation Quote Link to comment Share on other sites More sharing options...
kiall Posted April 4, 2007 Share Posted April 4, 2007 I'm after some photo's of the subject mounting/bracket, as fitted to a 2.5TD engined 110, need to see where the gearbox bracket bolts to & the route of the exhaust pipe.reason -- the bracket on mine is broken & I can't figure out how it's meant to fit together, got all the bits & new bracket/rubber bushes. cheers in anticipation i think from what i can remember from putting mies on it sits under the gearbox mount Quote Link to comment Share on other sites More sharing options...
western Posted April 4, 2007 Author Share Posted April 4, 2007 Cheers Kiall, would you be able to get me a couple of pictures from your truck ? Quote Link to comment Share on other sites More sharing options...
kiall Posted April 4, 2007 Share Posted April 4, 2007 Cheers Kiall, would you be able to get me a couple of pictures from your truck ? yup ill post them tomorrow if anyone doesnt Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted April 5, 2007 Share Posted April 5, 2007 Ralph, If you get stuck drop me a PM with your email addy - I'll send you the pics from my truck. Matt Quote Link to comment Share on other sites More sharing options...
western Posted April 5, 2007 Author Share Posted April 5, 2007 Cheers Matt, all photos will help, got a feeling I need to realign the exhaust pipe as well, PM with e.mail sent Cheers Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted April 5, 2007 Share Posted April 5, 2007 See if I can get some from under mine tommorow, If I just follow the Exhaust path I should be able to pretty much get what you're after I imagine... Quote Link to comment Share on other sites More sharing options...
western Posted April 5, 2007 Author Share Posted April 5, 2007 See if I can get some from under mine tommorow, If I just follow the Exhaust path I should be able to pretty much get what you're after I imagine... Brill, the subject bracket is attached to the left hand gearbox mount, got some pics from Matt, but more will be welcome. Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted April 6, 2007 Share Posted April 6, 2007 Right I got a few pics here - I'll upload some resized versions and if you need the full size (2576x1932) PM me an E-mail addy please And if you need anything else (More close ect...) Let me know and I'll crawl back under again. I found the Exhaust isn't actually attached around the gearbox on mine (Gearbox has been refitted though so that could explain it) but I think I found the bracket you needed, I took a load of pics anyway of some of the area - hope they can be of use to you Quote Link to comment Share on other sites More sharing options...
western Posted April 6, 2007 Author Share Posted April 6, 2007 Cheers , they help too, at least now I know how the bracket is meant to fit, I definitly need to realign the exhaust pipe to get it to sit in the correct place. Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted April 7, 2007 Share Posted April 7, 2007 could yours be different because of the 200tdi/r380? mines an lt-77 don't forget. Quote Link to comment Share on other sites More sharing options...
western Posted April 7, 2007 Author Share Posted April 7, 2007 No difference, my exhaust system is still the TD version except for the downpipe from turbo to first joint, all the mounts are TD type, all genuine factory built Tdi's have the hook & ruber ring type mounts. cheers for the thought anyway. Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted April 7, 2007 Share Posted April 7, 2007 No probs, just racking my brain Quote Link to comment Share on other sites More sharing options...
western Posted April 7, 2007 Author Share Posted April 7, 2007 No probs, just racking my brain go steady cos you'll only make it hurt Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted April 7, 2007 Share Posted April 7, 2007 Getting them photos make it hurt - I'm sure I left a dint in the transfer box housing Quote Link to comment Share on other sites More sharing options...
