255/85 onto a defender
JST
Mine are on Wolf rims and no issues on front (other than a slight reduction in steering lock) but on the rear, they caught the back edge of the eyebrow slightly. A trim from the rear most corner direct to the leading edge (get rid of the slight 'corner' they have) seemed to solve that.
With standard bump stops they rub slightly on the tub on compression but not worth worrying about.
So Td5 nearly sorted for the Pyrenees then!
CU
