Guest MJG Posted April 10, 2007 Share Posted April 10, 2007 Why does the hand book for my series III say I can change from low to high whilst moving but that I have to be stationary to go from high to low... Just curious really, I just would have thought one operation is a simple reversal of the other - but that could be my lack of (shortly to be further developed!!) mechanical knowledge. Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted April 10, 2007 Share Posted April 10, 2007 Common sense really, try changing from 4th to 1st in your road car at 70 mph, you'll hear the teeth strip off. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 10, 2007 Share Posted April 10, 2007 Personally I always stopped the Series before pulling the red lever in either direction, the yellow knob can be pushed down on the move. Quote Link to comment Share on other sites More sharing options...
Guest MJG Posted April 10, 2007 Share Posted April 10, 2007 Personally I always stopped the Series before pulling the red lever in either direction, the yellow knob can be pushed down on the move. That's what I thought would have been the best/safest option so was curious as to why the handbook says it's OK to go one way but not the other whilst moving. Quote Link to comment Share on other sites More sharing options...
Guest MJG Posted April 10, 2007 Share Posted April 10, 2007 Common sense really, try changing from 4th to 1st in your road car at 70 mph, you'll hear the teeth strip off. At that sort of speed yes of course it's common sense but I thought the operation would have been safe up to a certain given speed say 5-10 mph, but as the handbook says the vehicle has to be completely stationary. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted April 10, 2007 Share Posted April 10, 2007 Also engaging low selects 4WD so if you're in 2WD and the front & rear axles aren't going at the same speed there will be a shock to the transmission. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted April 10, 2007 Share Posted April 10, 2007 I agree, its not nice for the transmission, although I have been known to do it during trials when I needed a rapid turn, so went from 4wd to 2wd and powerslid aroun Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted April 10, 2007 Share Posted April 10, 2007 Anyone who has done extensive towing of heavy trailers or caravans with 2 1/4 litre powered series 1, 2 or 2a vehicles would or should be proficient at double declutching for changing transfercase ratios either up or down ,as it,s merely an extension of the technique used when selecting first or second gear in the main box. I towed a 2 1/2 ton caravan around Australia with an old 2A, and on long climbs, always mindful of the propensity of these gearboxes to break layshafts when towing in second gear, became quite adept at changing from high to low range once 3rd gear started to run out of puff, and back into high again when the road levelled out. It takes a bit of practice to make smooth crunch free changes but is doable. Just practice in 3rd and 4th gear and be progressive with clutch pedal operation until you get the hang of it, so as not to shockload the transmission. Bill. Quote Link to comment Share on other sites More sharing options...
